underpowerd Posted February 12, 2011 Author Share Posted February 12, 2011 good luck, finse. definitely give some thought into just fashioning some easy brackets from the get-go. my setup has held perfectly solid with the method in the pics, but a quick bracket would likely save you some time; i'd certainly do it that way if i was starting from scratch again. Link to comment Share on other sites More sharing options...
GTS Jeff Posted February 12, 2011 Share Posted February 12, 2011 in the picture, theres a great big glare box on the garage. It's pretty typical for OEM HID projectors to have squirrel finders. You can actually see them in the comparison pics he posted. IIRC, even the RX330 projectors do too. Some people's worldview would collapse knowing that a retro can produce glare too. Link to comment Share on other sites More sharing options...
finse Posted February 12, 2011 Share Posted February 12, 2011 good luck, finse. definitely give some thought into just fashioning some easy brackets from the get-go. my setup has held perfectly solid with the method in the pics, but a quick bracket would likely save you some time; i'd certainly do it that way if i was starting from scratch again. That's a great call. I'll be sure to take my time and get something made at a machine shop. Since this is going to be my permanent setup, might as well do it right! Link to comment Share on other sites More sharing options...
quick4dr Posted February 12, 2011 Share Posted February 12, 2011 I work for ACURA! give me a part number ill get prices at my price well below retail. that goes for any honda or acura part, just let me know Link to comment Share on other sites More sharing options...
Catalyst Posted February 12, 2011 Share Posted February 12, 2011 S2000?! "This is an adventure." Link to comment Share on other sites More sharing options...
underpowerd Posted February 12, 2011 Author Share Posted February 12, 2011 That's a great call. I'll be sure to take my time and get something made at a machine shop. Since this is going to be my permanent setup, might as well do it right! all you should need is something approximating the lgt shield (at least in the mounting areas) bolted to the back of the mdx shield, so you can drill right through and bolt right up to the lgt housing. that way, no spacers, and no inching along with the slotting. your call with machining, but i'm sure some cheap metal stock would do just fine if you snap off a few pics of the success, i'll be happy to add them to the reserve post at the beginning again, best luck. Link to comment Share on other sites More sharing options...
underpowerd Posted February 12, 2011 Author Share Posted February 12, 2011 I work for ACURA! give me a part number ill get prices at my price well below retail. that goes for any honda or acura part, just let me know i'd be curious for a quote on oem ballasts. i'd guess they might be denso units? Link to comment Share on other sites More sharing options...
quick4dr Posted February 12, 2011 Share Posted February 12, 2011 ill look at work monday Link to comment Share on other sites More sharing options...
murdoc158 Posted February 13, 2011 Share Posted February 13, 2011 Anyone know the difference between the 04-06 projector versus the 07-10 projector? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380314572030&viewitem=&sspagename=STRK:MEWAX:IT#ht_500wt_1182 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380314573285&viewitem=&sspagename=STRK:MEWAX:IT#ht_500wt_1182 Link to comment Share on other sites More sharing options...
finse Posted February 13, 2011 Share Posted February 13, 2011 Anyone know the difference between the 04-06 projector versus the 07-10 projector? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380314572030&viewitem=&sspagename=STRK:MEWAX:IT#ht_500wt_1182 This listing is for a halogen projector (H11), not a HID projector. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 16, 2011 Share Posted February 16, 2011 I work for ACURA! give me a part number ill get prices at my price well below retail. that goes for any honda or acura part, just let me know I used to work for Acura as well and you cannot buy these units by themselves as they come in an entire headlamp and are not sold seperately. The only thing you can buy seperate is the ballast, bulbs, and harness pieces. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Catalyst Posted February 16, 2011 Share Posted February 16, 2011 In for OEM ballast/bulb pricing! "This is an adventure." Link to comment Share on other sites More sharing options...
quick4dr Posted February 17, 2011 Share Posted February 17, 2011 pricing is oem ballast 170. oem bulb 175. i have a few sets of tsx projectors available, and shortly 2 MDX projectors!! Link to comment Share on other sites More sharing options...
murdoc158 Posted February 17, 2011 Share Posted February 17, 2011 pricing is oem ballast 170. oem bulb 175. i have a few sets of tsx projectors available, and shortly 2 MDX projectors!! Are the MDX projectors from 07+ ? If so PM me what you want for them. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 17, 2011 Share Posted February 17, 2011 $175 for just bulbs... What bulb is this for? Save yourself the time guys and pick up a set of Phillips 85122+ bulbs for less than $100. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Myevodream Posted February 17, 2011 Share Posted February 17, 2011 Finally getting around to starting my retro this weekend! Had to get another set of headlamps first just in case I F* up. Will post results when I am complete EDIT, so I was placing my projectors on and noticed that TRS sent me 2 lefts!! Damnit, now I have to wait for my right one to come in. double EDIT, just got off the phone with Matt over at TRS, says there's no real difference between the left and right projectors. Looks like the cutoff shields are mirrored of each other, but other than that the bowls look the same, so is it worth trying to find a right side one? He said this is the way they have always gone out. Also will put a piece of electrical wire at the glass to fit in their snug as I am doing the tsx-r lens Link to comment Share on other sites More sharing options...
finse Posted March 6, 2011 Share Posted March 6, 2011 all you should need is something approximating the lgt shield (at least in the mounting areas) bolted to the back of the mdx shield, so you can drill right through and bolt right up to the lgt housing. that way, no spacers, and no inching along with the slotting. your call with machining, but i'm sure some cheap metal stock would do just fine if you snap off a few pics of the success, i'll be happy to add them to the reserve post at the beginning again, best luck. So I finally got around to staring this project this weekend. I pulled apart my lamps last night, and spent the today fabbing up some mounting brackets. I found some nice aluminum shelfing matererials, and cut it up using a powered coping saw and my old trusty dremmel too. Here is one of the sets: http://www.slacktastic.net/car_pics/headlights/lgt-mdx-brackets.JPG They are not prefect, but they do fit. Here is a picture of the bottom one, fitting http://www.slacktastic.net/car_pics/headlights/lgt-lower-bracket.JPG Notice how I went around the notch, also note how thin it is up top, the bowl needs clearance here, and since this is not a structural component (just a spacer) it's no big deal. And here it's mounted http://www.slacktastic.net//car_pics/headlights/lgt-mdx-optics1.JPG Ok, so the good news is the projector seems to fit roughly. I have not yet removed the portion of the reflector from the howto, nor have I trimmed the shields. That's coming up this week. Now for some questions...... I have a total of 4 MDX sheilds, three of them are labeled 949 470R, one is labeled 949 470L. Looking at underpowerd's pictures, it appears my initial assumption of R=Right, L=Left is correct. Is it also a correct assumption that L = Drivers side, R= passengers side? Since I reused the original lower holes for mounting the projector assembly, is the projector going to be mis-aligned from the shroud when I try to re-assemble everything? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 7, 2011 Share Posted March 7, 2011 welcome to custom retrofitting. You'll find out once you start to put them back together what does and doesn't fit right. Then you just adjust whatever needs to be adjusted and move on until they work how you like. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
SpecBGuy Posted March 7, 2011 Share Posted March 7, 2011 why doesnt anybody just use sti hid projectors? Link to comment Share on other sites More sharing options...
GTS Jeff Posted March 7, 2011 Share Posted March 7, 2011 why doesnt anybody just use sti hid projectors? The 04-05 ones are reflector-based D2Rs...not really something that can be retrofitted. And the 06+...I dunno. It's not really readily available for cheap AFAIK Link to comment Share on other sites More sharing options...
mr_luv Posted March 7, 2011 Share Posted March 7, 2011 Fitment is off and the output is so so at best. why doesnt anybody just use sti hid projectors? Mr.350 Link to comment Share on other sites More sharing options...
underpowerd Posted March 8, 2011 Author Share Posted March 8, 2011 So I finally got around to staring this project this weekend. I pulled apart my lamps last night, and spent the today fabbing up some mounting brackets. I found some nice aluminum shelfing matererials, and cut it up using a powered coping saw and my old trusty dremmel too. Here is one of the sets: http://www.slacktastic.net/car_pics/headlights/lgt-mdx-brackets.JPG They are not prefect, but they do fit. Here is a picture of the bottom one, fitting http://www.slacktastic.net/car_pics/headlights/lgt-lower-bracket.JPG Notice how I went around the notch, also note how thin it is up top, the bowl needs clearance here, and since this is not a structural component (just a spacer) it's no big deal. And here it's mounted http://www.slacktastic.net//car_pics/headlights/lgt-mdx-optics1.JPG Ok, so the good news is the projector seems to fit roughly. I have not yet removed the portion of the reflector from the howto, nor have I trimmed the shields. That's coming up this week. Now for some questions...... I have a total of 4 MDX sheilds, three of them are labeled 949 470R, one is labeled 949 470L. Looking at underpowerd's pictures, it appears my initial assumption of R=Right, L=Left is correct. Is it also a correct assumption that L = Drivers side, R= passengers side? Since I reused the original lower holes for mounting the projector assembly, is the projector going to be mis-aligned from the shroud when I try to re-assemble everything? i think i see what you've done -- you're trying to keep the mdx shields fairly unmolested, which is pretty much impossible (without countersinking) to get everything to seat comfortably behind the lgt shroud/bezel. even with brackets, to achieve acceptable height, you're still going to be drilling through the mdx shield in the exact same location where i've slotted them in the pics (not simply using existing mount holes). the issue at hand is that the lgt lens holder (ergo, lens) sits a few mm higher on the shield relative to the mdx unit. the whole mdx optic needs to sit a few mm higher than it would if you just mounted using those existing lower bolt holes on the mdx shield... so naturally you need your mounting holes to be a few mm lower. on the bright side, it looks like you've found a terrific material in the Al stock. here's what i might try: line up the lgt shield to the the mdx shield via the 3 lens holder holes (which i believe are identically spaced on both units). theoretically, this should show you where your 4 mounting holes will need to be on the mdx shield for proper positioning/fit, and pretty much reveal the shape/size/drill points of brackets you'll require. get the top piece done first, test fit shroud to verify, then worry about the bottom (which will then show you exactly where to punch through). if you've measured and fastened the top correctly, you'll notice you can't use the stock bottom mdx shield holes; you have to drill through or slot mill. if this sounds complex, it may be; you're pioneering after all . if you feel the slightest hesitation with this route, you can always fall back on the slotting method if you feel more comfortable that way. Link to comment Share on other sites More sharing options...
finse Posted March 8, 2011 Share Posted March 8, 2011 i think i see what you've done -- you're trying to keep the mdx shields fairly unmolested, which is pretty much impossible (without countersinking) to get everything to seat comfortably behind the lgt shroud/bezel. even with brackets, to achieve acceptable height, you're still going to be drilling through the mdx shield in the exact same location where i've slotted them in the pics (not simply using existing mount holes). the issue at hand is that the lgt lens holder (ergo, lens) sits a few mm higher on the shield relative to the mdx unit. the whole mdx optic needs to sit a few mm higher than it would if you just mounted using those existing lower bolt holes on the mdx shield... so naturally you need your mounting holes to be a few mm lower. on the bright side, it looks like you've found a terrific material in the Al stock. here's what i might try: line up the lgt shield to the the mdx shield via the 3 lens holder holes (which i believe are identically spaced on both units). theoretically, this should show you where your 4 mounting holes will need to be on the mdx shield for proper positioning/fit, and pretty much reveal the shape/size/drill points of brackets you'll require. get the top piece done first, test fit shroud to verify, then worry about the bottom (which will then show you exactly where to punch through). if you've measured and fastened the top correctly, you'll notice you can't use the stock bottom mdx shield holes; you have to drill through or slot mill. if this sounds complex, it may be; you're pioneering after all . if you feel the slightest hesitation with this route, you can always fall back on the slotting method if you feel more comfortable that way. Thanks for your input on this. I think I did do a similar test as you are describing.. Both the LGT and MDX shields have three holes to help properly position the lens holder. I put the front to front (tab sticking out on either end) and inserted the lens holder. The bottom holes are close, but like you said, just a bit off. Luckily I have the two spare shields I can practice on to achieve the best possible fit. And worst case scenario, my pop has a ton more aluminum in his basement! I'll come back to this part of the retro in a week or two, in the mean time I am going to get more acquainted with the shrouds and 600 grit sandpaper Link to comment Share on other sites More sharing options...
Myevodream Posted March 8, 2011 Share Posted March 8, 2011 http://legacygt.com/forums/%5Bimg%5Dhttp://farm6.static.flickr.com/5260/5508313848_e3b9681ed8_z.jpgFinished this up last weekend, night and day difference. Sanded, painted black, with mdx projector bowls, and shields, as well as tsx-r glass. The pic of the cutoff is me holding the projector against the wall, the real cut off is amazing and will post pics of them on the car when the weather allows me to do so. 1 http://farm6.static.flickr.com/5260/5508313848_e3b9681ed8_z.jpg 2 http://farm6.static.flickr.com/5097/5508313430_8c44402f69.jpg 3 http://farm6.static.flickr.com/5215/5507715375_0156b0d224.jpg 4 http://farm6.static.flickr.com/5178/5507715453_429d9579a6.jpghttp://legacygt.com/forums/%3Ca%20href=%22http://www.flickr.com/photos/31031807@N04/5508313848/%22%20title=%22After%20by%20FourViewStudio,%20on%20Flickr%22%3E%3Cimg%20src=%22http://farm6.static.flickr.com/5260/5508313848_e3b9681ed8.jpg%22%20width=%22334%22%20height=%22500%22%20alt=%22After%22%20/%3E%3C/a%3E Link to comment Share on other sites More sharing options...
underpowerd Posted March 8, 2011 Author Share Posted March 8, 2011 ^ looking sharp! Link to comment Share on other sites More sharing options...
