GrampsWRX Posted February 2, 2010 Share Posted February 2, 2010 I have had several subies but with the 05 LGT wagon that I have, its has smelled of burning oil ever since I got my oil changed. that was 2 months ago. My WRX would smell for a couple days because of dripping. Do LGT's smell longer? There was no such smell before then. And the car doesn't seem to be leaking anywhere. Help.... Link to comment Share on other sites More sharing options...
captainhook Posted February 2, 2010 Share Posted February 2, 2010 I'm not suggesting this is your problem as it's pretty much impossible for me to guess, but recently I had a similar issue and it turned out my oil pan seal was leaking ever so slightly and dripping onto my exhaust manifold. I just had it resealed and the issue seems to have resolved itself. Link to comment Share on other sites More sharing options...
tbssubaru Posted February 2, 2010 Share Posted February 2, 2010 mine was the right inner cv boot Link to comment Share on other sites More sharing options...
c-lo Posted February 2, 2010 Share Posted February 2, 2010 ^^ pretty sure this was my problem too 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
GrampsWRX Posted February 3, 2010 Author Share Posted February 3, 2010 i only have 48k on it. I hope the cv boots are ok, but I will check them out tomorrow and see. Thanks for the help. Keep it coming. Link to comment Share on other sites More sharing options...
tbssubaru Posted February 3, 2010 Share Posted February 3, 2010 i'm at 53k , they die an early death because they are so close to the exhaust, or so i'm told Link to comment Share on other sites More sharing options...
Max Capacity Posted February 3, 2010 Share Posted February 3, 2010 120,200 miles, my boots are still original. OP, I would check to make sure the oil filter is not leaking. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
