Underdog Posted June 9, 2015 Share Posted June 9, 2015 Understood. I posted the fitment info for legacy owners that might search for that info in the future. Good luck with your project. The Crimson Dynamo Link to comment Share on other sites More sharing options...
mrp669 Posted April 15, 2017 Share Posted April 15, 2017 1. Power 2. Ground 3. MAF Signal 4. Temp Signal 5. Groound So for 05 obxt with same wiring as OP, would I use wires 4 & 5 for rewiring to another IAT for SD? Link to comment Share on other sites More sharing options...
utc_pyro Posted April 15, 2017 Share Posted April 15, 2017 So for 05 obxt with same wiring as OP, would I use wires 4 & 5 for rewiring to another IAT for SD? Yes. Flexconverter.com has a plug and play harness to do that if needed. Link to comment Share on other sites More sharing options...
stefanmalan3 Posted February 3, 2020 Share Posted February 3, 2020 Guys my 1999 legacy B4 RSK edition has a 4 wire MAF. What wires are they ? Sent from my SM-G970F using Tapatalk Link to comment Share on other sites More sharing options...
rhino6303 Posted April 21, 2021 Share Posted April 21, 2021 Bumping this for @k00laid83 . See post number 21 and 24. 21 has the pinout for our LGT maf. 24 has the pinout for the 08+ maf (the same as I PMd you). I forgot @Underdog listed the 08+ pinout on here and did the searching on my own. At least my pinout has been fact checked. Link to comment Share on other sites More sharing options...
