Instanced Posted February 11, 2011 Share Posted February 11, 2011 M3 Adjuster... That just sounds like your PS pump is broken... or on it's way out... mine never "locks" up... it's always free moving... take it to the dealer (if you're still under warranty) and show them what your seeing (if you can replicate the issue). Link to comment Share on other sites More sharing options...
miles Posted February 11, 2011 Share Posted February 11, 2011 My car makes the startup squeal. It occurs on cold mornings when I start my car the 1st time for that day. I park indoors at work. It never happens when I plug-in the block heater. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 11, 2011 Share Posted February 11, 2011 My car makes the startup squeal. It occurs on cold mornings when I start my car the 1st time for that day. I park indoors at work. It never happens when I plug-in the block heater. Mine lasted for a couple years, before it began to do the noise before it engaged the flywheel. When that started a couple weeks back, I knew it was time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
miles Posted February 11, 2011 Share Posted February 11, 2011 Mine lasted for a couple years, before it began to do the noise before it engaged the flywheel. When that started a couple weeks back, I knew it was time. Time for what? Link to comment Share on other sites More sharing options...
M3 Adjuster Posted February 13, 2011 Share Posted February 13, 2011 time for it to be replaced. and looking back a few posts it looks like replacing the starter resolved the issue for him. Link to comment Share on other sites More sharing options...
