urfsin Posted January 8, 2011 Author Share Posted January 8, 2011 IC.... $120 shipped piping.... about $100 Welding.... $40 All other little stuff to make it work.... about $40 Doing the work yourself....priceless. Slide It Sideways Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 8, 2011 Share Posted January 8, 2011 Any pics of the splitter? Link to comment Share on other sites More sharing options...
urfsin Posted January 8, 2011 Author Share Posted January 8, 2011 I will get some updated pics soon. The "splitter" is nothing fancy. It's just a piece of sheet metal cut to fit the hood scoop and help direct the air to the IC. Slide It Sideways Link to comment Share on other sites More sharing options...
gotsugg Posted January 8, 2011 Share Posted January 8, 2011 what this cost ?? make me a set??? =) I have the TMIC and the BOV flange you will need. I'll make you a good deal. Link to comment Share on other sites More sharing options...
urfsin Posted January 10, 2011 Author Share Posted January 10, 2011 Updated pics: #1) Good shot of the bracket holding the left side of the IC #2) The IC is now sitting level #3) Shot of the splitter and foam to seal off the air and direct it through the IC #4) Showing how the foam seals off the air when the hood is shut #5) Front view when hood is shut Slide It Sideways Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 10, 2011 Share Posted January 10, 2011 Thanks for the pics! I picked up a used AVO top mount and am considering a foam seal if I'm not creative enough to fab up an aluminum splitter. Link to comment Share on other sites More sharing options...
gotsugg Posted January 10, 2011 Share Posted January 10, 2011 Nice job. Where did you get the foam seal? Do you think there is enough room to use this TMIC with the LGT fitment Turbo's? Link to comment Share on other sites More sharing options...
urfsin Posted January 10, 2011 Author Share Posted January 10, 2011 I got the sheet metal and foam @ Home Depot The foam seal is made for window A/C units (to seal off any gaps). It comes as one large piece that I cut to fit my needs. Here is a link to the product: http://www.homedepot.com/h_d1/N-5yc1vZ1xhc/R-100209715/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053 Slide It Sideways Link to comment Share on other sites More sharing options...
urfsin Posted January 10, 2011 Author Share Posted January 10, 2011 As for LGT style turbo's, I think it would be very hard to make this IC work. If I was going to run a larger LGT style turbo, I would just get a Perrin (or other similar IC) My whole goal for this project was to be able to switch to WRX style turbos without having to do a full intake manifold swap. Slide It Sideways Link to comment Share on other sites More sharing options...
gotsugg Posted January 10, 2011 Share Posted January 10, 2011 I think it's a great option. Looks good. Link to comment Share on other sites More sharing options...
imblaze89 Posted January 22, 2013 Share Posted January 22, 2013 Trying to do something similar how did u make the flange for the stock bov to sit on? Link to comment Share on other sites More sharing options...
urfsin Posted January 23, 2013 Author Share Posted January 23, 2013 I bought a small piece of aluminum and cut it with jig saw for the rough shape, then used a grinder to finish it off. I did have to take that BOV piece, about four inch length of 1" pipe and IC to throttle body pipe to welder and have it all welded up. I am still rocking this IC and it works great for my needs. Slide It Sideways Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted January 23, 2013 Share Posted January 23, 2013 You can also buy the length of pipe with BOV tee already welded on, from eBay, cheap. Or JB weld, since it's not a critical structural joint. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
imblaze89 Posted February 10, 2013 Share Posted February 10, 2013 Thanx for the quik reply! Sounds easy enough.. so what is needed to do the vf39 swap? Link to comment Share on other sites More sharing options...
urfsin Posted February 10, 2013 Author Share Posted February 10, 2013 You just need to buy a VF39 / 43 / 48 and fab it all up. In all honesty though, at this point in time with the Process West intercooler (and choice of good LGT style turbo's) it's much easier to go that rout. Slide It Sideways Link to comment Share on other sites More sharing options...
RooTBeeR Posted February 11, 2013 Share Posted February 11, 2013 that finished shot with the hood closed looks purdy! "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RedDawg Posted February 13, 2013 Share Posted February 13, 2013 i dont think i ever posted up my DIY/ebay intercooler. total cost was <$200 http://i46.tinypic.com/29m8utj.jpg i did the same thing with the BOV & turbo flange, used a piece of aluminum, cut to rough size, and grinded it down the rest of the way Link to comment Share on other sites More sharing options...
JMLegacy Posted August 29, 2013 Share Posted August 29, 2013 Did u notice any performance increase (after or b4 tune)? Link to comment Share on other sites More sharing options...
1SIKLGT Posted August 31, 2013 Share Posted August 31, 2013 As for LGT style turbo's, I think it would be very hard to make this IC work. If I was going to run a larger LGT style turbo, I would just get a Perrin (or other similar IC) My whole goal for this project was to be able to switch to WRX style turbos without having to do a full intake manifold swap. Did u have any problems tuning it? I cant seem to get into boost! Sent from my LG-E970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
idiot4hire Posted September 1, 2013 Share Posted September 1, 2013 I have a similar set up in my garage that I am too embarrassed to put it on the for sale section. Link to comment Share on other sites More sharing options...
urfsin Posted September 1, 2013 Author Share Posted September 1, 2013 Did u have any problems tuning it? I cant seem to get into boost! Sent from my LG-E970 using Tapatalk 2 I did not tune it, Shamar of Infamous tuning did. I changed the boost pill size on his advice (I forgot what size). I was very happy with his tune and we had no problems tuning. This set up has been going strong for 3 years now. Slide It Sideways Link to comment Share on other sites More sharing options...
urfsin Posted September 1, 2013 Author Share Posted September 1, 2013 I have a similar set up in my garage that I am too embarrassed to put it on the for sale section. Did you ever get it on your car? It's not the prettiest set up, but it works really well IMO. Slide It Sideways Link to comment Share on other sites More sharing options...
idiot4hire Posted September 1, 2013 Share Posted September 1, 2013 Yea it fit just fine I just couldn't get the bpv hose to fit so I got a used Perrin Link to comment Share on other sites More sharing options...
Dinosaurs In Space Posted October 3, 2014 Share Posted October 3, 2014 Thread Revival.. urfsin, how did you deal with the hot side piping running into the A/C line at the firewall? I'm replicating your exact setup with a BW EFR6758 but am stuck.. :\ Link to comment Share on other sites More sharing options...
urfsin Posted October 4, 2014 Author Share Posted October 4, 2014 I un-cliped the A/C line from the bracket. It's in the center of the firewall if I remember correctly. There is a fair amount of flex in the A/C line. Also, if you are replicating my set up I ended up revising my hot side pipes. See post #24 for the update. I like the silicone pipes WAY more....there is more flex and it makes install a lot easier. Last note...the foam I used to seal off the IC when the hood is shut only lasted a few months before it fell off. If you can find out a better way to attach the foam or another way to seal it off let me know. Good Luck and post up your results! I have a feeling this TMIC set up can handle up to 350-375 HP no problem. Slide It Sideways Link to comment Share on other sites More sharing options...
