ALX2987 Posted January 14, 2010 Share Posted January 14, 2010 from all the research ive done, I understand going stage 2 makes the biggest performance jump, relatively easily. catless up, new DP and a tune seem to be the standard, but i was wondering what to do AFTER that? I would like to do one or 2 more bolt on things before i get pro tuned. So my question is what makes the most power (aside from a new turbo) headers? new top mount? My turbo is fine so i dont want to change it yet. so, what will produce the most bolt on power? thanks Link to comment Share on other sites More sharing options...
PineyLGT805 Posted January 14, 2010 Share Posted January 14, 2010 All depends on what kind of power and application you are wanting. Im no expert, but i know for stage 2 (at least to be reliable) you will wanna do a TMIC and maybe injectors and fuel pump. after your Cat Back, DP, UP, Intake, TMIC, Injectors, Fuel Pump and Tune you should be almost at stage 2 (minus clutch). After that, just getting bigger stuff like turbo, then maybe a bigger TMIC or FMIC, headers and a bunch of other stuff (stuff that i really don't plan on doing so i know not alot about) . If you search for "STAGE 2" or browse through ... here http://www.legacygt.com/forums/forumdisplay.php?f=12 here http://www.legacygt.com/forums/forumdisplay.php?f=84 here http://www.legacygt.com/forums/forumdisplay.php?f=73 and here http://www.legacygt.com/forums/forumdisplay.php?f=79 ... you should be well on your way to absorbing a CRAP load of SUBARU knowledge. Browse through the Walk Through sections as well to get a lot of step by step tutorials on most things you need and can do to your SUBARU Link to comment Share on other sites More sharing options...
fonts Posted January 14, 2010 Share Posted January 14, 2010 If you are running an 07 or newer you do not need a new UP. Simply DP and tune and technically you can do a stage 2 tune. Many members have encountered difficulties with the endtanks on the stock TMIC running stage 2 boost levels. Don't forget to consider upgrading things like springs, sways, brakes and tires before you consider adding a whole bunch more power. If you are considering a turbo upgrade in the future you may consider putting money away for a FMIC and turbo. If you want to take your time or aren't interested in FMIC then you can consider a new TMIC. Those upgrades should keep you happy for a bit anyways. Typically a turbo swap will require things like a bigger intake, injectors, fuel pump, FMIC or TMIC upgrade, suspension work, brake work and likely a catback and clutch in addition to your stage 2 upgrades. Sky is the limit ..... but once you start it's hard to stop. And once you start you start to notice some of the shortcomings of some of the other stock parts ..... Link to comment Share on other sites More sharing options...
PineyLGT805 Posted January 14, 2010 Share Posted January 14, 2010 Don't forget to consider upgrading things like springs, sways, brakes and tires before you consider adding a whole bunch more power. Yea forgot to add this (figured most do this before power anyways) FONTS: do you not suggest Fuel Pump and Injectors with a stage 2? I have had a few people mention doing this since (like you said) you notice the shortcomings of the stock parts once you upgrade to aftermarket Link to comment Share on other sites More sharing options...
fonts Posted January 14, 2010 Share Posted January 14, 2010 Yea forgot to add this (figured most do this before power anyways) FONTS: do you not suggest Fuel Pump and Injectors with a stage 2? I have had a few people mention doing this since (like you said) you notice the shortcomings of the stock parts once you upgrade to aftermarket No. You should be fine with stock FP and injectors until you upgrade your turbo. Things like bushings, tranny mount, etc. Once you get a STS you realize the stock bushings suck. One you replace your clutch you realize the stock tranny mount sucks. Once you add power you realize the stock engine mounts and pitch stopper suck. ..... etc. Link to comment Share on other sites More sharing options...
jmorris6689 Posted January 14, 2010 Share Posted January 14, 2010 im pretty happy with my current set up. im currently running a stage 2 setup wich includes:custom pro tune from dale at boxer4 racing 239AWHP 249AWTQ at 15.5 psi on a mustang dynoperrin tmicgreddy uncatted up pipeinvidia catless down pipemagnaflow catbackk&n typhoon intaketien s tech springskart boy short throw shifterdba rotors all aroundhawk hp+ pads all aroundim pretty happy with my current setup you can keep it cheap if you just wait on sales to come around, i have to say my best investment was the dyno tune. i was told i could have had 270whp if my wastegate actuator would have been tune able, i was told normally he will tune them to 19.5 psi on a stock turbo however my 15.5 increases the engine and turbo life. now im saving up for the clutch, injectors, fuel pump, and turbo upgrade:). but stage two legacys are a lot of fun so if i were you i would go for it Link to comment Share on other sites More sharing options...
shralp Posted January 14, 2010 Share Posted January 14, 2010 Stock fueling is totally fine for stage 2, new TMIC will allow your tuner to safely push your map more aggressively compared the stock intercooler which will give you more power, (and you solve potentially blowing out the stock endtanks). Swapping out the exhaust beyond your new DP will help free up some power too. If you want stealth, run an aftermarket 3" mid and y-pipe to stock muffs or do a full turboback if you want more noise. Link to comment Share on other sites More sharing options...
ALX2987 Posted January 14, 2010 Author Share Posted January 14, 2010 thanks for the info, i know if i upgrade the turbo ill need new injectors, fuelpump and a front mount, and springs and tires help with the drivability, but what im really asking is what mod will yield the best results with a pretty basic set up, aka downpipe and tune. im leaning towards a new top mount over a cat back. anyone have any other suggestions? Link to comment Share on other sites More sharing options...
fonts Posted January 14, 2010 Share Posted January 14, 2010 Top mount will allow you to run higher boost levels more safely. A catback will give you sound with minimal performance gains if any. Link to comment Share on other sites More sharing options...
peteyjr Posted January 14, 2010 Share Posted January 14, 2010 Both CBE and bigger TM will give more HP if tuned for it. Expect 8-10 at best. Changing to an AVO TM gave better torque down low and in the midrange. Infamous (our resident e-tuner) also tuned for my AVO watsegate actuator. It actually does help in keeping boost in the upper RPM ranges. In the end, many parts will slowly build your leggy into an awesome machine. Link to comment Share on other sites More sharing options...
ALX2987 Posted January 14, 2010 Author Share Posted January 14, 2010 thanks for the info and quick responses, since the catback is going on hold, what downpipes will bolt up to a stock catback? im looking for a catless, 3inch preferably, main concern is that it bolts to a stock catback. Link to comment Share on other sites More sharing options...
Strizzy Posted January 14, 2010 Share Posted January 14, 2010 This: http://www.fredbeansparts.com/servlet/the-2545/Invidia-Subaru-Legacy-GT/Detail (I'm running the catted one) with this: http://www.fredbeansparts.com/servlet/the-2651/3-Inch-Downpipe-to/Detail will bolt up to the stock CBE My bad luck build Link to comment Share on other sites More sharing options...
JaeGT Posted January 15, 2010 Share Posted January 15, 2010 if you have a MT http://legacygt.com/forums/showthread.php?t=128540 heard erz makes quality pieces and cheaper than the other competing products. if you have an AT http://legacygt.com/forums/showthread.php?t=128709 jump on the bandwagon. definately get the 3" to 2.5" adapter for ur stock CBE Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 15, 2010 Share Posted January 15, 2010 Get an upgraded TMIC. Link to comment Share on other sites More sharing options...
captainhook Posted January 15, 2010 Share Posted January 15, 2010 Both CBE and bigger TM will give more HP if tuned for it. Expect 8-10 at best. Changing to an AVO TM gave better torque down low and in the midrange. Infamous (our resident e-tuner) also tuned for my AVO watsegate actuator. It actually does help in keeping boost in the upper RPM ranges. In the end, many parts will slowly build your leggy into an awesome machine. Do you by chance have before/after data logs for the AVO actuator? I would be intrigued to see the difference in boost at high rpm. Link to comment Share on other sites More sharing options...
peteyjr Posted January 15, 2010 Share Posted January 15, 2010 Do you by chance have before/after data logs for the AVO actuator? I would be intrigued to see the difference in boost at high rpm. If you PM me I can send you a log of my latest tune with the AVO actuator. Infamous was mildly impressed with my up top boost holding. You can't change the VF 40 efficiency range but the actuator will help to some degree. Link to comment Share on other sites More sharing options...
johnboi85 Posted January 17, 2010 Share Posted January 17, 2010 my protune stage 2 invidia catless downpipe greddy evo2 catback perrin up-pipe grimmspeed x-over pipe perrin crank pulley re-inforced stock intercooler boosting 18.5psi on 92 btw, sea level 262awhp 300awtq on a dynojet Link to comment Share on other sites More sharing options...
BrooklynBoy Posted January 17, 2010 Share Posted January 17, 2010 There certainly is lots of info about going stage 2 here in our forum.......but I have yet to see an explaination of the pros/cons of catted vs catless downpipes ?!! Larger DP that's catted gives more HP ---but less than catless----or what??? Just curious. Do it right the first time.........or don't bother doing it at all. Link to comment Share on other sites More sharing options...
