NSFW Posted January 11, 2010 Share Posted January 11, 2010 LittleBlueGT tells me that ACT ships a small spacer with their flywheel that helps the clutch disengage without maxing out the pedal adjustment range. Is this basically just a washer that sits next to the pilot bearing? If so, what are the dimensions? I'm thinking I might buy one for my Bullyclutch setup to make the clutch adjustment easier. Installation should be on the 18th. Thanks! Link to comment Share on other sites More sharing options...
rao Posted January 11, 2010 Share Posted January 11, 2010 If there is a spacer it needs to cover the whole crankshaft end. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
NSFW Posted January 12, 2010 Author Share Posted January 12, 2010 If there is a spacer it needs to cover the whole crankshaft end. I can't picture what you're talking about. Please don't trick me into rotating my exhaust housing. Link to comment Share on other sites More sharing options...
Darkness of Death Posted January 12, 2010 Share Posted January 12, 2010 i didnt' notice any spacer in my kit Link to comment Share on other sites More sharing options...
rao Posted January 12, 2010 Share Posted January 12, 2010 I can't picture what you're talking about. Please don't trick me into rotating my exhaust housing. Funny If there is a spacer it either needs to move the flywheel closer to the transmission or the TOB closer to the pressure plate. To move the flywheel a spacer would need to mimic the end of the crankshaft and you would need longer flywheel bolts if the spacer was relatively thick. To move the TOB with the Subaru system would be a PITA. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
NSFW Posted January 13, 2010 Author Share Posted January 13, 2010 Thanks. How that I have the clutch/fly/pp in front of me, what you're saying makes more sense. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted January 13, 2010 Share Posted January 13, 2010 Wiener had one for sale: http://www.legacygt.com/forums/showthread.php?t=115844 Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
NSFW Posted January 13, 2010 Author Share Posted January 13, 2010 I don't want the flywheel that comes with it though, and I don't think it makes sense for him to sell them separately. I'm guessing the ACT flywheel needs the spacer, whereas the WRX flywheel can work without it. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted January 13, 2010 Share Posted January 13, 2010 I know. But maybe he can tell you the dimensions. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
