2.5gtbx_44 Posted December 29, 2009 Share Posted December 29, 2009 I dont know what is going on here! I am having what I believe is a misfire issue. It is however not throwing any codes. The symptoms are as follows: 1. When I free rev the car it stalls and dies 2. When driving the motor has hesitated and bucked really bad in any gear between 2k-3k rpm 3. The biggest issue is when it starts making boost it starts missing and breaking up real bad. Plugs have been replaced. There is fuel pressure. There seems to be no vacuum leaks or anything. I do not know what is going on. My tuner is kind of stumped as well. Any and all advice is wanted, needed, and greatly appreciated. Below is a video of the car on the dyno doing the breaking up thing. IMG_0339.flv video by s13slider44 - Photobucket@@AMEPARAM@@http://vid79.photobucket.com/player.swf?file=http://vid79.photobucket.com/albums/j133/s13slider44/IMG_0339.flv@@AMEPARAM@@vid79@@AMEPARAM@@79@@AMEPARAM@@j133/s13slider44/IMG_0339 Link to comment Share on other sites More sharing options...
Ridgeracer Posted December 29, 2009 Share Posted December 29, 2009 Well I would start by checking the coil packs are secured on each plug and make sure the little spring is still there on the inside. Next make sure the connectors for them are snug. Do you have aftermarket headers? If you do, maybe you have a crack. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 29, 2009 Author Share Posted December 29, 2009 No, no aftermarket headers. Link to comment Share on other sites More sharing options...
Spec B Posted December 29, 2009 Share Posted December 29, 2009 Do you have the ability to log? I am assuming no oil or coolant loss? How is your MPG? Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 29, 2009 Author Share Posted December 29, 2009 Yea I can log on my accessport. No oil or coolant loss. MPG sucks right now!! Link to comment Share on other sites More sharing options...
j255c Posted December 29, 2009 Share Posted December 29, 2009 check o2 sensor. Log fbkc and kc. Compression test. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 29, 2009 Author Share Posted December 29, 2009 Which o2 sensor? If it were bad wouldnt it throw a code? Whats fbkc and kc? Link to comment Share on other sites More sharing options...
fishbone Posted December 29, 2009 Share Posted December 29, 2009 fbkc = feedback knock correction kc = knock correction I would start doing some logging if I were you to see what the tune is looking like Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 29, 2009 Author Share Posted December 29, 2009 can those parameters be logged using the accessport? Link to comment Share on other sites More sharing options...
j255c Posted December 29, 2009 Share Posted December 29, 2009 Download Rom Raider, its a free application. Im assuming you dont datalog the car very often? Do you have a tactrix cable? Your tuner should have checked these things while it was on the dyno imo. Also checked your video, thats a lot of black smoke. Could be a valve not sealing. When my engine died and 2 valves werent sealing it used to stall at idle, but also would dump enough oil that the person following me would get coated on their windshield. Firstly, check your tune. Check your oil, vacuum lines, etc again. Datalog your car. Check your oil consumption. If none of that is showing red signs, id get a compression leak down test and cross your fingers. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 29, 2009 Author Share Posted December 29, 2009 I do not datalog at all really. I do not have a tactrix cable. Im assuming he did. As far as the valve i dont think that is it cause my oil consumption is close to none. I do not blow oil like the way you did. Link to comment Share on other sites More sharing options...
j255c Posted December 29, 2009 Share Posted December 29, 2009 Where are you located? Call your tuner and ask him if he datalogged the front o2 sensor and checked the tune. If you're located near westchester I could try to help you out. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 29, 2009 Author Share Posted December 29, 2009 Im in the bronx. I will call him and ask him tomorrow. Any help will be greatly appreciated. Link to comment Share on other sites More sharing options...
05lgt5spd Posted December 29, 2009 Share Posted December 29, 2009 I would do the easiest things in this order clean your maf. check your plugs If I recall, the bucking is due to a lean condition. Did it randomly just start, or did you change anything. My car was bucking and dying on idle, took 5 minutes and it was a dirty maf. Sometimes its easy to overlook the small stuff. You coudl have a ripped turbo inlet hose but its torn in a spot where you can see it. Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 29, 2009 Author Share Posted December 29, 2009 The plugs are brand new. Will try cleaning the maf and running some injector cleaner. Tomorrow. The bucking just started randomly then, randomly stopped. Link to comment Share on other sites More sharing options...
fishbone Posted December 30, 2009 Share Posted December 30, 2009 What plugs did you use? Are you positive they were installed correctly? Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 30, 2009 Author Share Posted December 30, 2009 NGK iridiums one step colder. Im pretty sure they were installed correctly as they were done by from what I can tell a competent tech. Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 30, 2009 Author Share Posted December 30, 2009 Ok so I was able to find a loose connection between my intake and inlet hose. I reconnected and tightened them. That seems to have taken care of the bucking and outright running like poo normally. The breaking up in boost is still occurring. I dumped in a bottle of lucas oil fuel treatment/injector cleaner for good measure. Didnt do any good for the issue but, didnt hurt either. I was able to do some datalogs on my accessport but, I do not know how to view them or post them here. If someone can help me out with that it would be greatly appreciated. Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 30, 2009 Author Share Posted December 30, 2009 So I figured out how to open the logs. Now I need to know what I need to be looking for. The car is also dying again after free revving the car. The rpms climb normally then just drop to zero and the cars dies. Link to comment Share on other sites More sharing options...
Ridgeracer Posted December 31, 2009 Share Posted December 31, 2009 Did you change anything recently just before all this occurred? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 31, 2009 Author Share Posted December 31, 2009 well i had plugs installed, a breather kit, an up pipe cause my old one had a crack in it. I also put another turbo in. Link to comment Share on other sites More sharing options...
Ridgeracer Posted December 31, 2009 Share Posted December 31, 2009 Is the breather kit for the pcv? Could you plumb the pvc system back together? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted December 31, 2009 Author Share Posted December 31, 2009 yea it is. I dont know if i can cause, i dont know if i have all the hoses for the factory system. Could that be the cause of my problems? Link to comment Share on other sites More sharing options...
Ridgeracer Posted January 1, 2010 Share Posted January 1, 2010 I think another member had problems once with a breather kit. Its a start. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
ktmrider Posted January 1, 2010 Share Posted January 1, 2010 Do you have a boost/vac gauge? If so what are the readings at idle? Those symptoms have been known to happen with poor fuel pressure and/or control. A vacuum leak in or around the intake manifold will change the FPR signal, making it run very rich in vacuum and lean when in boost. Since you did so many things at once like mentioned go back one at a time if ALL your vac lines check out. GL. Link to comment Share on other sites More sharing options...
