legacee Posted December 1, 2009 Share Posted December 1, 2009 anyone tried these? apparently the timing must be adjusted with them Link to comment Share on other sites More sharing options...
FocuS Posted December 1, 2009 Share Posted December 1, 2009 I'd just run Iridium and save your $ Just my .02... Link to comment Share on other sites More sharing options...
Bdubs Posted December 2, 2009 Share Posted December 2, 2009 Don't run anything other than oem spec. NGK's. Anything else, and the car will run like shit. Link to comment Share on other sites More sharing options...
kaz98gt Posted December 2, 2009 Share Posted December 2, 2009 i've got bosch fusions and she sounds great, better fuel economy, better throttle response. way, way, way surpasses the original plugs that were in there, but then again those had nothing left on them Link to comment Share on other sites More sharing options...
httrdd Posted December 2, 2009 Share Posted December 2, 2009 i've got bosch fusions and she sounds great, better fuel economy, better throttle response. way, way, way surpasses the original plugs that were in there, but then again those had nothing left on them About to do mine too. Any recomendations on wire to go with the Bosch? Link to comment Share on other sites More sharing options...
kaz98gt Posted December 3, 2009 Share Posted December 3, 2009 Sorry httrdd I haven't done anything with the wires yet mainly due to the fact that all of my money is kaput senior in highschool does not have a fantastic budget unfortunately. I'll do some research on the wires though...what have you found? Link to comment Share on other sites More sharing options...
httrdd Posted December 3, 2009 Share Posted December 3, 2009 Still looking at different brands and reading more threads. I will let you know what I come up with. The motor has 90,000, and since I am a new owner I want to change out the plugs and plug wires so I know where to go maintenance wise. I am just really glad the car does not have coil packs like my F150 did! Hey when I was in highschool I played BBall and worked part time as a waiter. It is possible! Link to comment Share on other sites More sharing options...
Bdubs Posted December 3, 2009 Share Posted December 3, 2009 As I said, your car will eventually begin to run like shit with Bosch plugs. Fuel economy and misfires are common after a few thousand miles. Use the NGK Vpower coppers #BKR5E-11 Or NGK platinum's #PFR5B-11 (these last longer than the coppers, although I think the coppers perform better) As far as wires, Magnecor makes a damn good set, they aren't cheap, but they are worth the cash. Get the 8MM wires, they'll probably last you 15k miles. And, of course, I can also say NGK wires will also work 8MM as well, but you probably can cut the life expectancy of these in half compared to the magnecors. http://www.clubplug.net/ Link to comment Share on other sites More sharing options...
httrdd Posted December 3, 2009 Share Posted December 3, 2009 Thanks! Link to comment Share on other sites More sharing options...
prodriver1 Posted December 9, 2009 Share Posted December 9, 2009 i used NGK platinums and 5 miles later my $12 plugs were toasted. i got iridium high performance plugs ($28 each) and they work very well. i also installed sti plug wires an coil. works perfectly. Link to comment Share on other sites More sharing options...
