absolutsnwbrdr Posted November 29, 2009 Share Posted November 29, 2009 My sister just got a 2007 outback about 3 weeks ago and her highbeams quit working. She could take it to the dealer to have them look at it, but they arent a Subaru dealer, so I'd probably have better luck troubleshooting it than they will. She lives in North Carolina and I'm going to see her next weekend so I'd like to come up with some ideas before I get down there. I looked in my manual (2005 legacy/outback) and as far as I can tell, the lowbeams and highbeams are on the same fuse for each side of the car, so I dont think its a fuse. Also, I doubt that both highbeam bulbs burnt out at the same time. I'm planning on checking all the fuses, just to be sure, but I just wanted to know if anyone has encountered this problem. Thanks! Link to comment Share on other sites More sharing options...
StoplightAssassin Posted November 29, 2009 Share Posted November 29, 2009 Also, I doubt that both highbeam bulbs burnt out at the same time. don't assume anything. check the bulbs first Link to comment Share on other sites More sharing options...
dudeondacouch Posted November 29, 2009 Share Posted November 29, 2009 don't assume anything. check the bulbs first Had one lowbeam burn out, then the other the very next day. Link to comment Share on other sites More sharing options...
Impulse Posted November 29, 2009 Share Posted November 29, 2009 don't assume anything. check the bulbs first yes, its possible that low start temperatures coupled with a power spike blew both at the same time w/o affecting fuse. Link to comment Share on other sites More sharing options...
Gire Posted November 29, 2009 Share Posted November 29, 2009 Had one lowbeam burn out, then the other the very next day. +2 Happens all the time thanks to the current differences and loads placed on the remaining bulb. always replace both bulbs when one goes... otherwise you'll be replacng the other one pretty soon! Link to comment Share on other sites More sharing options...
absolutsnwbrdr Posted November 30, 2009 Author Share Posted November 30, 2009 interesting... I dont think I've ever had that happen, but looks like I'll be checking fuses and bulbs then. For some reason I didnt think that it could be that simple... *hoping it is* Link to comment Share on other sites More sharing options...
OhBe1 Posted December 2, 2009 Share Posted December 2, 2009 I, too, have had bulb pairs burn out in quick succession. I figure it's due to some high-quality manufacturing process. Reduces production variation. Besides, one of my rules is to check if the quick & cheap solution works first, even though it may be less likely. IIRC, '07 has high-beam DRL, right? Does she remember to turn on her low-beams? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
absolutsnwbrdr Posted December 3, 2009 Author Share Posted December 3, 2009 Im not sure about the DRL's on the '07's, but I'm fairly certain that she turned on the low beams. I'll be getting down there tomorrow evening, so I'll wait until Saturday to check the bulbs. thanks guys. Link to comment Share on other sites More sharing options...
