1astrokeit Posted November 22, 2009 Share Posted November 22, 2009 well i got my car tuned and went to do a pull for infamous and it slippied just a lil bit, so im wondering if any one has any advice on clutches that i should go with, i seen act clutches but they are too expensive for me especially around this time of year. i was looking at spec but havent seen any reviews on the spec,i heard that exedy clutches arent so good, im not sure of any other cluthes for subaru that are best bang for the buck. i have the following mods and dont look to go any further then this beside a fmic possibly: mods: cobb catted dp gutted up perrin catback grimmspeed ebcs perrin drop in filter infamous 93 tune Link to comment Share on other sites More sharing options...
Gire Posted November 23, 2009 Share Posted November 23, 2009 Search. There's a hundred threads here on aftermarket clutch set ups. Search ACT clutch. Link to comment Share on other sites More sharing options...
rnstein69 Posted November 23, 2009 Share Posted November 23, 2009 act clutch + 06 wrx flywheel will come out to almost the same amount installed as going with oem LGT clutch and dual-mass flywheel. Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted November 23, 2009 Share Posted November 23, 2009 ACT with the oem OR Streetlite ACT flywheel. Have this setup... GREAT Link to comment Share on other sites More sharing options...
qikslvr Posted November 23, 2009 Share Posted November 23, 2009 Here is a link to my SPEC Stg2 Clutch and LWFW review: http://legacygt.com/forums/showthread.php?t=78095&highlight=spec+clutch+review Let's kick this pig! Link to comment Share on other sites More sharing options...
1astrokeit Posted November 23, 2009 Author Share Posted November 23, 2009 I'm not worried bout labor cus I'm doin the work, its easier when your a mechanic. Is act worth 700? I don't need a puck design do I? I want something streetable. I have past experience with spec as I had one in my mustang but how do you like your spec so far after the problems qikslvr? Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted November 23, 2009 Share Posted November 23, 2009 I have intake/up pipe/down pipe/catback/TMIC/Pulley with a stage 2 93 octane TDC tune. And with that setup I was starting to slip especially when cold outside. Once I added the ACT I had no more issues with slipping and love the added grip compaired to very little increase in pedal effort. Link to comment Share on other sites More sharing options...
1astrokeit Posted November 23, 2009 Author Share Posted November 23, 2009 but i read that you have to change flywheels when you use an act clutch, correct? Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted November 23, 2009 Share Posted November 23, 2009 yes. you MUST have a flywheel designed for a 06+ wrx to match the clutch design. Fred Beans hooks up the combos though. Will take care of you im sure. Link to comment Share on other sites More sharing options...
1astrokeit Posted November 23, 2009 Author Share Posted November 23, 2009 ok i will see what happens, not sure what i want to do. trying not to change factory flywheel Link to comment Share on other sites More sharing options...
qikslvr Posted November 23, 2009 Share Posted November 23, 2009 I'm not worried bout labor cus I'm doin the work, its easier when your a mechanic. Is act worth 700? I don't need a puck design do I? I want something streetable. I have past experience with spec as I had one in my mustang but how do you like your spec so far after the problems qikslvr? The issue's I had have become pretty much standard with the aftermaket clutchs. I've walked several people with different brand setups through adjusting the clutch pedal throw and the TOB squeal fix. Once you get them quieted down it's all good. It may have been different if I stayed with the stock flywheel(yes, the SPEC clutches fit the OE LGT flywheel). So far, my clutch has held up great for 30K+ miles with power levels up to 350whp. I won't lie; it gets a little tempermental now and then in heavy traffic, but for the most part it's been great and has performed exactly as expected at the track and on the street. When I have to do another clutch I'll probably go back to the stock flywheel to kill some gear noise but I'll keep the clutch setup. Let's kick this pig! Link to comment Share on other sites More sharing options...
