clark687 Posted November 19, 2009 Share Posted November 19, 2009 How can a torque converter blow/break? Dealership said i blew it?So what they think. Link to comment Share on other sites More sharing options...
burnout8488 Posted November 19, 2009 Share Posted November 19, 2009 What do you even DO to your car to cause these problems man?! Are you a new driver? Didn't you make a thread about revving past the redline awhile back? Link to comment Share on other sites More sharing options...
-TT- Posted November 19, 2009 Share Posted November 19, 2009 http://lmgtfy.com/?q=how+to+fail+at+car+ownership Link to comment Share on other sites More sharing options...
-TT- Posted November 19, 2009 Share Posted November 19, 2009 also i know Wikipedia isn't the best source but this article about torque converter failure is fairly accurate: Capacity and failure modes As with a basic fluid coupling the theoretical torque capacity of a converter is proportional to http://upload.wikimedia.org/math/d/c/4/dc4b1b8496ed22d29049ca8542d3416e.png, where r is the mass density of the fluid, N is the impeller speed (rpm), and D is the diameter. In practice, the maximum torque capacity is limited by the mechanical characteristics of the materials used in the converter's components, as well as the ability of the converter to dissipate heat (often through water cooling). As an aid to strength, reliability and economy of production, most automotive converter housings are of welded construction. Industrial units are usually assembled with bolted housings, a design feature that eases the process of inspection and repair, but adds to the cost of producing the converter. In high performance, racing and heavy duty commercial converters, the pump and turbine may be further strengthened by a process called furnace brazing, in which molten brass is forced into seams and joints to produce a stronger bond between the blades, hubs and annular ring(s). Because the furnace brazing process creates a small radius at the point where a blade meets with a hub or annular ring, a theoretical decrease in turbulence will occur, resulting in a corresponding increase in efficiency. Overloading a converter can result in several failure modes, some of them potentially dangerous in nature: Overheating: Continuous high levels of slippage may overwhelm the converter's ability to dissipate heat, resulting in damage to the elastomer seals that retain fluid inside the converter. This will cause the unit to leak and eventually stop functioning due to lack of fluid. Stator clutch seizure: The inner and outer elements of the one-way stator clutch become permanently locked together, thus preventing the stator from rotating during the coupling phase. Most often, seizure is precipitated by severe loading and subsequent distortion of the clutch components. Eventually, galling of the mating parts occurs, which triggers seizure. A converter with a seized stator clutch will exhibit very poor efficiency during the coupling phase, and in a motor vehicle, fuel consumption will drastically increase. Converter overheating under such conditions will usually occur if continued operation is attempted. Stator clutch breakage: A very abrupt application of power can cause shock loading to the stator clutch, resulting in breakage. When this occurs, the stator will freely counter-rotate the pump and almost no power transmission will take place. In an automobile, the effect is similar to a severe case of transmission slippage and the vehicle is all but incapable of moving under its own power. Blade deformation and fragmentation: Due to abrupt loading or excessive heating of the converter, the pump and/or turbine blades may be deformed, separated from their hubs and/or annular rings, or may break up into fragments. At the least, such a failure will result in a significant loss of efficiency, producing symptoms similar (although less pronounced) to those accompanying stator clutch failure. In extreme cases, catastrophic destruction of the converter will occur. Ballooning: Prolonged operation under excessive loading, very abrupt application of load, or operating a torque converter at very high RPM may cause the shape of the converter's housing to be physically distorted due to internal pressure and/or the stress imposed by centrifugal force. Under extreme conditions, ballooning will cause the converter housing to rupture, resulting in the violent dispersal of hot oil and metal fragments over a wide area. Link to comment Share on other sites More sharing options...
Gire Posted November 20, 2009 Share Posted November 20, 2009 No personal attacks... that one was too far. Deleted before reported. Link to comment Share on other sites More sharing options...
katalyst Posted November 21, 2009 Share Posted November 21, 2009 did they have any suggestions as to why it failed? i think yours is (unfortunately) the first i've heard on here failing, your car is pretty new too if i recall. Link to comment Share on other sites More sharing options...
clark687 Posted November 21, 2009 Author Share Posted November 21, 2009 Understood, i dont no. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 22, 2009 Share Posted November 22, 2009 It's very very hard to make a TC fail at your power level. It's also very new (MY09). I suggest you go to a dealer that won't try to take your money wrongfully, or set this one straight. It's most likely not your fault. The 08s had some interesting TC issues, so it it's entirely possible the issue was not completely rectified come '09. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
burnout8488 Posted November 23, 2009 Share Posted November 23, 2009 It's very very hard to make a TC fail at your power level. It's also very new (MY09). I suggest you go to a dealer that won't try to take your money wrongfully, or set this one straight. It's most likely not your fault. The 08s had some interesting TC issues, so it it's entirely possible the issue was not completely rectified come '09. I thought all subaru's had a rev limiter.Will i was driving down the road, accidently hit into nuetral, and the engine went right up to 8k. And made a weird sound. Any ideas what is wrong? Link to comment Share on other sites More sharing options...
fishbone Posted November 23, 2009 Share Posted November 23, 2009 clark, request that the dealer tell you why the torque converter failed. How is the car acting? what is it NOT doing right? There is a service bulleting related to a manufacturer defect on late 08 and early 09 Legacy GT automatic transmission torque converters. Ask the dealer about it, have them show it to you and have them check if your car is affected. Link to comment Share on other sites More sharing options...
ehsnils Posted November 23, 2009 Share Posted November 23, 2009 Considering that there is a rev limiter that should kick in I would say that you would really have to try to abuse the car to break the converter. And even then I suspect that something else would give up first. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 23, 2009 Share Posted November 23, 2009 8k on a lgt torque converter in neutral is not a cause for a problem by itself. Is someone suggesting they just break at 8k? [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
