kaz98gt Posted November 4, 2009 Share Posted November 4, 2009 Is that "steam cleaning" where you just put some water into the throttle body safe? I just get the feeling that it would mess up the combustion process... Link to comment Share on other sites More sharing options...
rmb2485 Posted November 4, 2009 Share Posted November 4, 2009 Is that "steam cleaning" where you just put some water into the throttle body safe? I just get the feeling that it would mess up the combustion process... Its perfectly safe, as long as you go slooooooow. By slow, I means taking fifteen minutes to drizzle twelve ounces of water into the motor. The danger is if you dump a bunch of water in at once it will fill the combustion chamber and hydrolock the motor. Best case in that scenario is the motor stalls, you pull the spark plugs and crank the motor to shoot the water out the holes and then replace the plugs, change the oil and everything is fine. Worst case, you bend a connecting rod and destroy the motor. Link to comment Share on other sites More sharing options...
kaz98gt Posted November 5, 2009 Share Posted November 5, 2009 So, as long as it's done at a snail pace, everything should be fine. Sounds like patience is necessary haha.How much water should be added, and what good will come out of this "steam cleaning"? Link to comment Share on other sites More sharing options...
amp27 Posted December 16, 2009 Share Posted December 16, 2009 what good comes out of it? Link to comment Share on other sites More sharing options...
