2009 Seatbelt Chime Disable *with pics*
OK so I decided to investigate today, and it turns out that the mechanism inside the seatbelt works on a ground circuit
In layman terms, that means the following:
Seat belt out = switch allows +12V to pass through.
Seat belt inserted = switch is disconnected.
Here we go:
Step 1: Stick your fingers in here and pull outwards (towards you).
http://img242.imageshack.us/img242/9495/1mediumh.jpghttp://img242.imageshack.us/img242/1mediumh.jpg/1/w800.png
Step 2: Buckle now open.
http://img197.imageshack.us/img197/9663/2mediumq.jpghttp://img197.imageshack.us/img197/2mediumq.jpg/1/w800.png
Step 3: Push the little black tab in and the circuitboard should pop out easily. Note the white sliding switch attached to the board.
http://img504.imageshack.us/img504/8782/3mediuml.jpghttp://img504.imageshack.us/img504/3mediuml.jpg/1/w800.png
Step 4: Slide the white switch off the board, you don't need this anymore.
http://img242.imageshack.us/img242/7470/4medium.jpghttp://img242.imageshack.us/img242/4medium.jpg/1/w800.png
Step 5: Put everything back together.
Done!
This disabled the seat belt chime for the drivers side, I'd assume not for the passenger side but I will have to test that later.
Also disables the 6 chimes when you first start the car.
I did this on a 2009 Legacy 2.5i, but I'd imagine it would be the same for all models.
  • 5 months later...
  • 1 year later...
Yep just did this to the 09 Spec, and did it to the 05 years ago.
The drivers seat buckle is like made to easily remove that cover. You don't need to touch the passenger seat buckle.
Engine Build - Click Here
