LGTspecB1657615261 Posted October 9, 2009 Share Posted October 9, 2009 To those running E85, does your car stumble and almost stall during a hot start? For me, warm start is fine.... even if the coolant temp needle is just past the first dash its fine. When the coolant temp needle is right in the middle (i.e. hot), it starts VERY rough. The engine rocks, bucks, and barely starts.... then finally the idle stabilizes. I find that holding the gas in slightly and keeping the RPM right around 2,000 for a bit helps. Anyone else experience this? Why is it? Its embarrasing when you are at a gas station or somewhere else in public and you just got out of your car for a short moment. Link to comment Share on other sites More sharing options...
FireB Posted October 9, 2009 Share Posted October 9, 2009 Maybe running too rich? I have a same issue (Just 93oct though) right now with fuel trim being +15% Warm is ok, but Hot engine, it will almost die (All the lights on the dash comes up for like 0.1 sec) and raise the rev a little. Link to comment Share on other sites More sharing options...
yamie700 Posted October 9, 2009 Share Posted October 9, 2009 Maybe running too rich? I have a same issue (Just 93oct though) right now with fuel trim being +15% Warm is ok, but Hot engine, it will almost die (All the lights on the dash comes up for like 0.1 sec) and raise the rev a little. Wouldn't +15% mean the car is adding fuel? i.e. ecu thinks it is running lean so its adding fuel at idle? -15% would mean the ecu is taking fuel out, so its running rich to begin with right? Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted October 9, 2009 Author Share Posted October 9, 2009 latencies and scalar are all good, it has nothing to do with trims. Its an issue with starting the car when it is hot. +15% does mean its adding fuel, so it thinks not enough is going in (i.e. lean). Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted October 9, 2009 Author Share Posted October 9, 2009 I read some posts in the Nasioc E85 FAQ thread, and others have the same exact thing with hot starting issues. Not everyone though... must be a function of the injectors or spark plugs? Link to comment Share on other sites More sharing options...
Ridgeracer Posted October 9, 2009 Share Posted October 9, 2009 Maybe running too rich? I have a same issue (Just 93oct though) right now with fuel trim being +15% Warm is ok, but Hot engine, it will almost die (All the lights on the dash comes up for like 0.1 sec) and raise the rev a little. You need to start a thread for your problem. You have a post MAF leak somewhere. See you already did... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Infamous1 Posted October 9, 2009 Share Posted October 9, 2009 I had this issue although I was on colder range plugs. If I gave it gas slightly at the same time it wouldn't be an issue. This led me to believe if was related to some sort of startup enrichment not defined. The cooler the engine the more fuel that is injected based upon the defined tables. Also only on E85 as well. Link to comment Share on other sites More sharing options...
Legend Posted October 9, 2009 Share Posted October 9, 2009 OP, this is not a common issue with E85. It's something with your setup.. whether it's bad plugs, leaky injector, I don't know. You can test whether it's flooding by keeping the gas pedal all the way down why starting. If that improves hot starts you could be overfueling for whatever reason. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted October 9, 2009 Author Share Posted October 9, 2009 Well I will have to start diagnosing it. The car starts just fine unless it was just shut off and is still hot. I wonder what would cause that? I am switching to 93 octane soon to see what problems persist. I have a rough idle issue, and a major CL stutter issue. From what I can tell, and from the carb-cleaner test, I have not post-MAF leaks. My front O2 is solid and reading well. hmph. hope its not the injectors. Those sucked to get in. I wonder if the plugs are bad after 6k miles? That would suck. Short life... What plugs should I get? I guess I could replace them for grins. That reminds me, I need to change my oil! Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted October 9, 2009 Author Share Posted October 9, 2009 I will try to log my rough start, if that's possible. My guess is A/F correction is all over the place. I think the injector tuning is good, because it idles good and behaves normally otherwise. Link to comment Share on other sites More sharing options...
Legend Posted October 9, 2009 Share Posted October 9, 2009 What plugs should I get? For E85, stock heat range. Not colder. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
FireB Posted October 9, 2009 Share Posted October 9, 2009 You need to start a thread for your problem. You have a post MAF leak somewhere. See you already did... Thanks for the heads up. Link to comment Share on other sites More sharing options...
