E-Tank Posted October 5, 2009 Share Posted October 5, 2009 My last oil change was 2,800 miles ago. Previously I have always used Mobile 1, but Pennzoil Plat. was on sale, so I took it. Just checked my oil this morning and saw that I was way low. I rushed over to Autozone on my lunch break and it took 1.5 quarts more of PP (haha pp) to reach full. Should I be worried? Is PP just crappy oil? I know Boxers have a tendency to eat oil, but 1.5 quarts over 2800 miles? inb4 "you're retarded for not checking your oil regularly." Link to comment Share on other sites More sharing options...
quicklook2 Posted October 5, 2009 Share Posted October 5, 2009 did you replace the oil drain crush gasket? is anything leaking? does not sound normal. my 92 legacy only uses about 1/4 of a quart between oil changes and my 2000 gt less then that. Link to comment Share on other sites More sharing options...
slimjoe Posted October 5, 2009 Share Posted October 5, 2009 With about 75k on the motor, I find that mine eats about half a quart of PP every 4-5k miles. I usually just chalk it up to the turbo eating it. As for you though, 1.5 quarts within 2800 miles does seem high. I'd just say keep watching it. Maybe when it was last changed, it wasn't filled all the way. Link to comment Share on other sites More sharing options...
E-Tank Posted October 5, 2009 Author Share Posted October 5, 2009 Hmmm. Yeah, a slow leak would make sense. This is the first change I've ever had done at Jiffylube. All the guys working in there looked to be about 12 years old. I'll have to climb under the car today and check the plug. Link to comment Share on other sites More sharing options...
E-Tank Posted October 5, 2009 Author Share Posted October 5, 2009 I'm at 55k. You use PP for every change? Is it good stuff? I never noticed much loss when using Mobile 1. The car seems to be running stronger tham ever. I did just complete my last revision with Infamous1, so in the last month I have done a TON of 3rd gear data logging. I wonder if that could be the cause of so much lost oil. With about 75k on the motor, I find that mine eats about half a quart of PP every 4-5k miles. I usually just chalk it up to the turbo eating it. As for you though, 1.5 quarts within 2800 miles does seem high. I'd just say keep watching it. Maybe when it was last changed, it wasn't filled all the way. Link to comment Share on other sites More sharing options...
slimjoe Posted October 5, 2009 Share Posted October 5, 2009 Yep, since I got her at around 12k, I've been using PP with every change. I can't really comment on if it's good or not but I've never had an issue with it. It seems to do its job well enough Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 6, 2009 Share Posted October 6, 2009 PP is good oil Ive used it in other vehicle never my subbie not yet anyway. I run Pennzoil 5w30 dino oil and it eats 1/2 qrt btwn changes and I have a N/A so that could be the norm for our engines and that oil. I now however run Quarkerstate 5w30 and don't have any problems. I would glance at the turbo for leaks check your filter for leaks then check the bottom of the heads. I If you dont find any leaks the engine is consuming that oil and make it a point to check it more often or consider switching next oil change to a different oil. I never trust my oil changes to anyone else b/c ive only ever had bad experiences two times they didnt fill it back up with oil, once paid for synth got dino, third they didnt put the right filter on. When I got my new Subbie I just took matters into my own hands use Subaru filters and either QS or Penz Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted October 6, 2009 Share Posted October 6, 2009 Did you check the oil level right after the oil change? The Jiffy-tards might not have added enough oil to begin with. Link to comment Share on other sites More sharing options...
quicklook2 Posted October 6, 2009 Share Posted October 6, 2009 i would NEVER trust my car to a quick lube place. i bet the crush washer is leaking. has to be changed EVERY oil change. Link to comment Share on other sites More sharing options...
timmahh Posted October 6, 2009 Share Posted October 6, 2009 i would NEVER trust my car to a quick lube place. i bet the crush washer is leaking. has to be changed EVERY oil change. True dat! I forgot to get a crush washer from the Acura dealer once and went with one from Kragen... Oil Leak! Had to go back to the dealer and get a factory one. On your work order from jiffylube does it say how much oil they put into the car? The manual says 4.2 quarts.. Link to comment Share on other sites More sharing options...
atc5 Posted October 6, 2009 Share Posted October 6, 2009 compression and leakdown test time next time use mobil 1, it's the best oil ever Link to comment Share on other sites More sharing options...
scoobydoobie Posted October 6, 2009 Share Posted October 6, 2009 Jiffy lube. That's your problem. Link to comment Share on other sites More sharing options...
E-Tank Posted October 6, 2009 Author Share Posted October 6, 2009 Thanks for all the input. Crush gasket makes sense. I'd never used Jiffylube before, but it is right down the street. I would do it myself, but I don't have jack stands or a place to work. Next change I'll take it to the dealer and put Mobile Uno in it like I always did before. Link to comment Share on other sites More sharing options...
quicklook2 Posted October 6, 2009 Share Posted October 6, 2009 you have not one friend with a driveway or garage to lend you? go to subaru and buy 6 oil filters and 6 crush gaskets. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 7, 2009 Share Posted October 7, 2009 Aww man, it looks like Rao didn't make it in time for this thread... He would've known the answer to your oil woe's. On a more serious note, last time I did an oil change on the 92 I put in 4.2 quarts of Pennzoil 10W-40 High Mileage Conventional motor oil and I haven't lost a drop. Come to think of it, the car hasn't burned a drop since I bought it. I got the car 20K miles ago and at 154K she's never leaked or burned any oil, and I check it about once or twice a week (Just in case). Conventional oil FTW. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted October 7, 2009 Share Posted October 7, 2009 If Jiffy-screwed put in only 4.2 quarts it would not be totally full. In my 2.5i I have to add almost a full 5 quarts to get it totally full. I am guessing leaking filter, drain plug, or it was underfilled at the time of the oil change. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 7, 2009 Share Posted October 7, 2009 Why would they only put 4.2 quarts in an EJ25? 4.2 quarts is the capacity for the EJ22, they should either be able to look up the EJ25 capacity on their computer, or just open up the owners manual to figure it out. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted October 7, 2009 Share Posted October 7, 2009 ...look up the EJ25 capacity on their computer, or just open up the owners manual to figure it out. JiffyLube?.... computer?.... MANUAL??!! Bwahhhahahaha! Link to comment Share on other sites More sharing options...
