rosscarlson Posted September 15, 2009 Share Posted September 15, 2009 Guys, Not sure if this is the right forum, if not please forgive me. I'm just coming up on 6k miles and will be doing some fluid changing. Obviously I'll be doing oil/filter but I'm wondering what other fluids I should consider changing out. I've run about 600 track miles so far and have another 200 or so left this season. I change my brake fluid regularly (Motul Super Blue) so I'm all set there. What others? Transmission? Differential? Thanks for any input! -Ross Link to comment Share on other sites More sharing options...
rao Posted September 15, 2009 Share Posted September 15, 2009 If you do track it a lot, I would change everything. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rosscarlson Posted September 15, 2009 Author Share Posted September 15, 2009 That's sorta what I'm thinking - but I must admit I'm not much of a mechanic! What fluids would I change? Brakes, transmission, diff, engine oil - but what else? Link to comment Share on other sites More sharing options...
rao Posted September 15, 2009 Share Posted September 15, 2009 Coolant Transmission Rear Differential Brake Fluid Clutch Fluid (same as brake fluid, but don't skip it) Power Steering Fluid None of them are too difficult to change. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
wpmarky Posted September 15, 2009 Share Posted September 15, 2009 don't forget the wiper fluid darn bugs. Link to comment Share on other sites More sharing options...
Bones Posted September 15, 2009 Share Posted September 15, 2009 Guys, Not sure if this is the right forum, if not please forgive me. I'm just coming up on 6k miles and will be doing some fluid changing. Obviously I'll be doing oil/filter but I'm wondering what other fluids I should consider changing out. I've run about 600 track miles so far and have another 200 or so left this season. I change my brake fluid regularly (Motul Super Blue) so I'm all set there. What others? Transmission? Differential? Thanks for any input! -Ross Hey Ross When I first went to the Track I changed it all to Motul Oil/Brake/Diff/Tran not a sponsor or anything. But I did my home work on it before I hit the track. It stays cooler than most fuilds for a longer time. Subaru Race teams use it .. its expensive compared to most. But I wanted the Best in my car against the BMWs & Mustangs @ Buttonwillow Raceway. Since than I use it all the time !!! Link to comment Share on other sites More sharing options...
rosscarlson Posted September 15, 2009 Author Share Posted September 15, 2009 Thanks Bones, I use Motul for my brake fluid already but am slightly partial to Mobile 1 synthetic motor oil (as I ran that in my 350z). I'll certainly look at the others though, I assume there are walk troughs around for the procedures? Link to comment Share on other sites More sharing options...
rao Posted September 15, 2009 Share Posted September 15, 2009 Uh, oh Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
pillboy Posted September 16, 2009 Share Posted September 16, 2009 Bladder fluid. It is still ugly. Link to comment Share on other sites More sharing options...
Bones Posted September 18, 2009 Share Posted September 18, 2009 Thanks Bones, I use Motul for my brake fluid already but am slightly partial to Mobile 1 synthetic motor oil (as I ran that in my 350z). I'll certainly look at the others though, I assume there are walk troughs around for the procedures? Just as a heads up Mobil 1 is not a good recommendation for our engines. Do a search & You'll see want I mean. I m a big fan as well of Mobil 1, but I have heard of engine trouble in the Boxers from WRX's Guys to Legacy's. Thats why I do Motul only but there are ours the go with Castoral, ask about Oils on the Forums its a hot topic. Link to comment Share on other sites More sharing options...
