jeztom24 Posted September 13, 2009 Share Posted September 13, 2009 I have a 2009 legacy 2.5i with 4000 miles. I was on my way back to school with the heat on and I was going up a steep hill and when accelerated over 3750 rpm the inside of the car started to smell. I don’t know if the engine is still breaking in or what. Should i be worried? Link to comment Share on other sites More sharing options...
quicklook2 Posted September 13, 2009 Share Posted September 13, 2009 ah, yeah. back to the dealer asap and tell exactly what happened. could be the coatings on new parts but you paid enough for subaru to figure it out. how fast were you going? and in what gear? stick or auto? Link to comment Share on other sites More sharing options...
TurboWill Posted September 13, 2009 Share Posted September 13, 2009 OK I have an 09 also. Does it smell like antifreeze? Im battling it out now with subaru. There trying to tell me that the 08-09 models use a new antifreeze and the smell is normal. Its BS. I think its a problem with the head gasket. Link to comment Share on other sites More sharing options...
jeztom24 Posted September 13, 2009 Author Share Posted September 13, 2009 i was going about 55 60 and its an auto ah, yeah. back to the dealer asap and tell exactly what happened. could be the coatings on new parts but you paid enough for subaru to figure it out. how fast were you going? and in what gear? stick or auto? Link to comment Share on other sites More sharing options...
jeztom24 Posted September 13, 2009 Author Share Posted September 13, 2009 yeah its a weird smell i cant tell what it is. OK I have an 09 also. Does it smell like antifreeze? Im battling it out now with subaru. There trying to tell me that the 08-09 models use a new antifreeze and the smell is normal. Its BS. I think its a problem with the head gasket. Link to comment Share on other sites More sharing options...
quicklook2 Posted September 13, 2009 Share Posted September 13, 2009 3750 sounds high in drive at 55-60 mph. it should go to subaru monday morning. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 13, 2009 Share Posted September 13, 2009 Unless it smells all the time, it's normal. You floored it, something got hot and made a smell. It did it once. Forget about it. When it does it all the time, then you worry about it. If you take it to the dealer, all they are gonna say is they can't find anything. If it was a Head Gasket issue, it would do it more often, you'd have coolant in the oil or oil in the coolant. You'd be low on coolant or the coolant tank would overflow occasionally. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
snow05gtRI Posted September 13, 2009 Share Posted September 13, 2009 3750 sounds high in drive at 55-60 mph. it should go to subaru monday morning. the OP was going uphill, the car probably downshifted. Link to comment Share on other sites More sharing options...
quicklook2 Posted September 13, 2009 Share Posted September 13, 2009 earlier i asked what gear and he just said automatic. IF it was in drive (4th) that sounds high, IF it was downshifted that may be about right. short of going for a drive, which i am not going to do right now, the op needs to clear up with as much info as possible what he did. Link to comment Share on other sites More sharing options...
jeztom24 Posted September 13, 2009 Author Share Posted September 13, 2009 It down shifted and thats y the rpm was high earlier i asked what gear and he just said automatic. IF it was in drive (4th) that sounds high, IF it was downshifted that may be about right. short of going for a drive, which i am not going to do right now, the op needs to clear up with as much info as possible what he did. Link to comment Share on other sites More sharing options...
HanGmaN Posted September 14, 2009 Share Posted September 14, 2009 i have a 2010 with 5k miles on it and i used my heat full blast the first time last night and i did smell something... odd, but i think its just because its a new car and tuning on the heat is prolly heating up new plastic or something.. i don't think you should be worried about it Link to comment Share on other sites More sharing options...
Power4 Posted September 14, 2009 Share Posted September 14, 2009 My '09 LGT makes an odd smell sometimes when I really get on it. It used to do it more often when it was brand new but now that it has over 3,000 miles on it I don't smell it as much. I think it's normal for our cars and apparently goes away in time. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted September 14, 2009 Share Posted September 14, 2009 It is probably just cosmoline or the like burning off from around hot engine/exhaust parts. I wouldn't worry too much about it unless it never goes away or happens all the time. Link to comment Share on other sites More sharing options...
peteyjr Posted September 14, 2009 Share Posted September 14, 2009 When I bought my WRX new it came with weird smells at first that eventually went away. Link to comment Share on other sites More sharing options...
