PutnamCO Posted September 3, 2009 Share Posted September 3, 2009 I got my new VF52 installed yesterday, and received a rom from Infamous, but EcuFlash won't recognize my ECU. After connecting the green connectors, the car went into test mode, but the EcuFlash text read the following: [23:43:01.254] EcuFlash Version 1.42.2595 [23:43:01.254] OS Version Windows Vista [23:43:01.254] Qt Version 4.5.0 [23:43:01.285] 56 memory models read. [23:43:01.285] scanning for metadata models in C:/Users/spencer abrahamson/Desktop/Putnam/EcuFlash/rommetadata [23:43:02.283] 343 ROM metadata models scanned. [23:43:02.283] checksum module "subarudbw" loaded. [23:43:02.283] checksum module "mitsucan" loaded. [23:43:02.283] flashing tool "wrx02" loaded. [23:43:02.283] flashing tool "wrx04" loaded. [23:43:02.283] flashing tool "sti04" loaded. [23:43:02.283] flashing tool "sti05" loaded. [23:43:02.283] flashing tool "mitsukernel" loaded. [23:43:02.283] flashing tool "mitsukernelocp" loaded. [23:43:02.283] flashing tool "mitsubootloader" loaded. [23:43:02.299] flashing tool "shbootmode" loaded. [23:43:02.299] flashing tool "shaudmode" loaded. [23:43:02.299] flashing tool "subarucan" loaded. [23:43:02.299] flashing tool "mitsucan" loaded. [23:43:32.750] A2WF200N (277 tables) inheriting 32BITBASE (662 tables) [23:43:32.906] 1048576 byte image read. [23:44:07.357] 1048576 byte image read. [23:44:19.207] Using interface OpenPort 1.3b Mitsu TX38A7Wz199774d5087e4352b444e04ab8bd76e1acafec00 [23:44:19.207] interface close [23:44:19.207] unable to connect to vehicle interface. [23:44:19.222] interface close [23:44:36.938] Using interface OpenPort 1.3b Mitsu TX38A7Wz199774d5087e4352b444e04ab8bd76e1acafec00 [23:44:36.938] interface close [23:44:36.938] unable to connect to vehicle interface. [23:44:36.938] interface close I am wondering if the Tactrix cable is faulty, as my Accessport will read my ECU. I also tried using the Tactrix cable to connect my Accesport to the OBD II and that did not work (not sure if this is possible anyway). Any help would be greatly appreciated as I cannot wait to use my new turbo. Thanks. Link to comment Share on other sites More sharing options...
LGT Dave Posted September 3, 2009 Share Posted September 3, 2009 Are you saying the AP is still married to your car? If you're planning on switching to an opensource tune from Infamous you can't use the AP anymore. It needs to be divorced from your ECU first and then everything should work. Link to comment Share on other sites More sharing options...
NSFW Posted September 3, 2009 Share Posted September 3, 2009 Open Windows' Device Manager and disable all other serial ports. Then see what happens. I have to disable and re-enable my WBO2's serial adaptor when I reflash. Link to comment Share on other sites More sharing options...
PutnamCO Posted September 3, 2009 Author Share Posted September 3, 2009 Thanks for the help, unfortunately my problems got far worse than what I posted. Once I un-married the Accessport and disconnected the green cables, my car read Er Hc and will not start. I have already started another thread about this, but thanks again for your thoughts. Link to comment Share on other sites More sharing options...
johnnymack Posted September 3, 2009 Share Posted September 3, 2009 I had a similiar issue... http://legacygt.com/forums/showthread.php?t=119535 Link to comment Share on other sites More sharing options...
PutnamCO Posted September 3, 2009 Author Share Posted September 3, 2009 Glad to see your issue was resolved. My ECU is in transit to Salt Lake to be reprogrammed. It's amazing to me that a company can sell me a $700 piece of electronics that renders my car unusable, and they do not offer any sort of compensation for a rental or anything like that. They even admitted that "it sounds like the Accessport was responsible for the problem". At least I'll have my car back in 3-5 days. Link to comment Share on other sites More sharing options...
Legend Posted September 3, 2009 Share Posted September 3, 2009 Glad to see your issue was resolved. My ECU is in transit to Salt Lake to be reprogrammed. It's amazing to me that a company can sell me a $700 piece of electronics that renders my car unusable, and they do not offer any sort of compensation for a rental or anything like that. They even admitted that "it sounds like the Accessport was responsible for the problem". At least I'll have my car back in 3-5 days. I had to do the same thing - remove my ecu and overnight it to Cobb. In my case it wasn't my fault (I've never owned an AP) or Cobb's, but the previous owner's fault by putting the wrong rom on the ecu. In my case, Cobb was the hero because they restored my ecu for free and shipped the same day even though they weren't responsible for the rom corruption. I'd say Cobb is a great company from what I've seen and they definitely step up to the plate even when they don't have to. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
tommypenguin Posted September 3, 2009 Share Posted September 3, 2009 If you have any issues after you get your ecu back let me know. We could meet up and always try my tactrix cable if you can't get yours to work, good luck. Link to comment Share on other sites More sharing options...
PutnamCO Posted September 4, 2009 Author Share Posted September 4, 2009 Thanks very much, I really appreciate it. This has been a total nightmare, and I'll let you know if things don't start going well. Link to comment Share on other sites More sharing options...
PutnamCO Posted September 4, 2009 Author Share Posted September 4, 2009 An update: I mailed the ECU to Cobb yesterday, and spoke with them today and they told me they fixed it and it would be overnighted to me this afternoon. When I got the UPS tracking number, it said the scheduled delivery date was 9/9/09. I called to make sure this was not the case, and Cobb told me that they had accidentally mailed the ECU UPS Ground, instead of overnight, and it would be here 9/9. Link to comment Share on other sites More sharing options...
LGT Dave Posted September 5, 2009 Share Posted September 5, 2009 An update: I mailed the ECU to Cobb yesterday, and spoke with them today and they told me they fixed it and it would be overnighted to me this afternoon. When I got the UPS tracking number, it said the scheduled delivery date was 9/9/09. I called to make sure this was not the case, and Cobb told me that they had accidentally mailed the ECU UPS Ground, instead of overnight, and it would be here 9/9. Man, that sucks. Are they charging you for fixing it? If so, I'd be asking for some of that money back. Link to comment Share on other sites More sharing options...
