brandonGT Posted August 29, 2009 Share Posted August 29, 2009 ok so I'm installing an unequal length header tommorrow on an already stage 2 vf40. My question is, do I need an updated tune or will my current protune map be sufficient? if not, what specific changes in the tune will be needed to accomodate the new part? Link to comment Share on other sites More sharing options...
brandonGT Posted August 29, 2009 Author Share Posted August 29, 2009 any help? Link to comment Share on other sites More sharing options...
johnnymack Posted August 29, 2009 Share Posted August 29, 2009 You will need a new tune/adjustment. Link to comment Share on other sites More sharing options...
johnAWD Posted August 29, 2009 Share Posted August 29, 2009 You will not need a tune. Your current tune will be fine, but a new tune will help you extract more out of the car. Link to comment Share on other sites More sharing options...
Infamous1 Posted August 29, 2009 Share Posted August 29, 2009 With UEL you should be alright. One way to know for sure Link to comment Share on other sites More sharing options...
brandonGT Posted August 29, 2009 Author Share Posted August 29, 2009 With UEL you should be alright. One way to know for sure Ok that's what I thought. It is being installed right now, I will datalog tonight. But, to take full advantage of this mod, what changes to the tune should be made? More degrees of AVCS in the mid range and up top? Link to comment Share on other sites More sharing options...
Infamous1 Posted August 30, 2009 Share Posted August 30, 2009 I wouldn't bother, avcs will change VE. If done, at the same time there will need to be timing and wgdc changes as well. Link to comment Share on other sites More sharing options...
johnnymack Posted August 30, 2009 Share Posted August 30, 2009 You will not need a tune. Your current tune will be fine, but a new tune will help you extract more out of the car. So intalling headers won't create an overboost/fuel cut condition on the same tune? Link to comment Share on other sites More sharing options...
PhilT Posted August 30, 2009 Share Posted August 30, 2009 So intalling headers won't create an overboost/fuel cut condition on the same tune? Nope Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
johnAWD Posted August 30, 2009 Share Posted August 30, 2009 ^^ What Phil said. Link to comment Share on other sites More sharing options...
brandonGT Posted August 30, 2009 Author Share Posted August 30, 2009 Well it's installed and I did some datalogs. Keep in mind I am using the same map as before. First thing I noticed is the car is down about 1.0 psi all across the rpm band, is this normal? Link to comment Share on other sites More sharing options...
