fatboy1214 Posted August 25, 2009 Share Posted August 25, 2009 hey i am kinda new to the forums but i have a question would it be possible to fit a bigger engine in my car i have a 97' Subaru legacy outback i was gunna see if you could say drop a small block in or if theres not enough room and possible what else you would have to do to make it run right PS I've never done an engine swap so if you have helpful hints that would be much appreciated Link to comment Share on other sites More sharing options...
rao Posted August 25, 2009 Share Posted August 25, 2009 a small block is going to be a little difficult. You can fit lots of Subaru engines - go to http://www.nasioc.com "subaru conversions" forum and you will find all of the information you need. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
E-Tank Posted August 25, 2009 Share Posted August 25, 2009 I smell troll... If not, though, you should do a full STI swap. There's some info on it here in the forums. If you're on a tight budget you could go for a 2.0 wrx swap too. Link to comment Share on other sites More sharing options...
rao Posted August 25, 2009 Share Posted August 25, 2009 Got me Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
fatboy1214 Posted August 25, 2009 Author Share Posted August 25, 2009 hey thanks i am definitely on a high schooler budget and i figured if i could that would sweet and the ultimate sleeper Link to comment Share on other sites More sharing options...
ehsnils Posted August 25, 2009 Share Posted August 25, 2009 No it wouldn't be the ultimate sleeper. I suspect that most LGT:s and 3.0:s will outrun you due to better grip and handling. If you want to make a sleeper, check out this thread instead: http://legacygt.com/forums/showthread.php?t=68613 Link to comment Share on other sites More sharing options...
fatboy1214 Posted August 25, 2009 Author Share Posted August 25, 2009 yea i for sure wouldnt mess with that thanks for all the ideas Link to comment Share on other sites More sharing options...
