amason Posted August 19, 2009 Share Posted August 19, 2009 Hi all, My '05 LGT needs a new clutch at 96k kms, hoping for some opinions on the following options. Assume for the discussion that they all cost the same, and that I have no brand preference. Bully is local, so I kinda would like to support them, but either way, they can resurface and balance any flywheel option I end up with. 1) Resurfaced stock fw and Bully clutch (they now make an LGT fitment) 2) Used Spec fw and Bully clutch (still LGT fitment) 3) Used '07 LGT fw and Bully clutch (LGT fitment?) 4) Used ACT streetlite fw and Bully clutch (WRX fitment) 5) New '06 WRX fw and ACT clutch package from FredBeans If I end up with the Bully (and it's currently leaning that way), which stage to get? I'm almost at stage 2 power, and hope to be there shortly. Don't mind losing a tiny bit of drivability for a good performance gain, and I almost never drive in stop and go traffic. Thanks, Andy Link to comment Share on other sites More sharing options...
rao Posted August 19, 2009 Share Posted August 19, 2009 I would go with option #7 - 06 WRX Flywheel, 06 WRX clutch, 06 WRX Pressure Plate. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 20, 2009 Share Posted August 20, 2009 Option 5. OEM flywheel, ACT clutch for an 06 WRX. Get it from Fred Beans, or another ACT vendor that'll get you a good price. Stick with a stage 1 clutch or you'll be sorry. Rao - What's with your signature invoice note? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
schwinn Posted August 20, 2009 Share Posted August 20, 2009 Just bought myself option 5 based on what many others have recommended... so I'd say that one as well. Well known clutch, and a good streetable FW. Link to comment Share on other sites More sharing options...
