legacyforlife Posted August 19, 2009 Share Posted August 19, 2009 i found a wrecked 04 wrx and got the turbo headers intercooler, everything and want to put it on my car but the only thing i cant figure out is the oil lines where do i connect them to? i heard there are bolts on the block or heads or something. can u please tell me i cant figure it out and no one is helping i now wat ur gona say why dont u just get a turboed car, cause im freakin pore thats why i got this from a junk yard for 40 bucks yeah everything for 40 bucks Link to comment Share on other sites More sharing options...
legacyforlife Posted August 19, 2009 Author Share Posted August 19, 2009 http://www.cardomain.com/ride/861819 heres wat i want to do he explins everything but the oil lines and thats the only thing i cant figure out Link to comment Share on other sites More sharing options...
seanrose Posted August 25, 2009 Share Posted August 25, 2009 try nasioc Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 25, 2009 Share Posted August 25, 2009 on the turbo models the oil filter plate where it mates to the block has an output and input. No a N/A they do not so you will have to get that piece off the donor car Link to comment Share on other sites More sharing options...
heresmymind Posted September 14, 2009 Share Posted September 14, 2009 they are called OIL galley plugs, there are 2. 1 is for your stock oil pressure sensor. the 2nd is just to the left of the throttle body. look underneath it to the left and you'll see a flat ALlen bolt, you remove this and put in the adapter NPT, then you run that to the turbo, for the drain line you take off your oil pan, drill a hole ABOVE the mail oil line so u dont get backup and then you weld in a bung for the oil fitting. -B Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 14, 2009 Share Posted September 14, 2009 they are called OIL galley plugs, there are 2. 1 is for your stock oil pressure sensor. the 2nd is just to the left of the throttle body. look underneath it to the left and you'll see a flat ALlen bolt, you remove this and put in the adapter NPT, then you run that to the turbo, for the drain line you take off your oil pan, drill a hole ABOVE the mail oil line so u dont get backup and then you weld in a bung for the oil fitting. -B There is also a return line plug on the pass side head iirc Link to comment Share on other sites More sharing options...
legacyforlife Posted September 15, 2009 Author Share Posted September 15, 2009 where is that return line at? i put it on my car already i had to use my stock headers and made a up pipe till i can get bigger ones cause i dont want to cut anything, i used the oil sensor for feed line and return line i put inbetween the heads and valve covers theres little D shaped plugs on the back i just took out the bottem one and mad e a thing for it it worked ok but i think theres to much oil in the valve cover for it to drain good from the turbo and i dont want to drill into my oil pan Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 19, 2009 Share Posted September 19, 2009 You're gonna boost a 98 2.5L N/A engine?!?!?! Good luck. any bets on how long the head gaskets will last? Those cars blow through enough head gaskets without a turbo. Nevermind the NA version has a higher compression ratio. Personally I say a month, I'll be generous. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 20, 2009 Share Posted September 20, 2009 Well idk how long it will last depends on the boost and well his setup is. using that crescent shaped plug for a return isnt bad but I would look for a better drainage point and tapping your oil pan isnt hard at all and is a lower point on the engine which will help to drain better Link to comment Share on other sites More sharing options...
legacyforlife Posted September 24, 2009 Author Share Posted September 24, 2009 im only pushing 5 to 6 psi so its not bad and i just did the headgasket with solid metal gasket and its lasted me so far so i proved you wrong on that and im running a top mount intercooler with the stock turbo so its not that big i had to use my stock headers not the wrx cause i didnt want to cut out the frame so i ran a pipe to the turbo and back to 2.5 inch piping with a 5zigen muffler, i want to get some better headers cause these ones are pretty small and i deleted my cat so i used spark plug non foulers and it worked i got all my info from subaru legacy international they have people that do this set up all the time Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 24, 2009 Share Posted September 24, 2009 im only pushing 5 to 6 psi so its not bad and i just did the headgasket with solid metal gasket and its lasted me so far so i proved you wrong on that and im running a top mount intercooler with the stock turbo so its not that big i had to use my stock headers not the wrx cause i didnt want to cut out the frame so i ran a pipe to the turbo and back to 2.5 inch piping with a 5zigen muffler, i want to get some better headers cause these ones are pretty small and i deleted my cat so i used spark plug non foulers and it worked i got all my info from subaru legacy international they have people that do this set up all the time yeah you could switch to borla replicas and fabb a uppipe to fit and keep you DP turbo back section. Link to comment Share on other sites More sharing options...
