wnstn Posted August 13, 2009 Share Posted August 13, 2009 Hi everyone, Quick question - recently I have found that my engagement point is higher than usual *(this is a 6 spd btw), do you guys know why this is? The car is an 07 spec b and has just under 40k kilometers on it. If the clutch is done (at such a low km) - is it covered under warranty? any help is appreciated and thanks in advance, - W Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 13, 2009 Share Posted August 13, 2009 driver error clutch pedal should be adjustable. if anything, you should be covered under warranty, winston ~ Link to comment Share on other sites More sharing options...
wnstn Posted August 13, 2009 Author Share Posted August 13, 2009 driver error clutch pedal should be adjustable. if anything, you should be covered under warranty, winston ~ Thx Perry - I just called markham subaru and they told me (from their recollection) that it's not covered b/c it's a consumable part and that it's a hydrolic clutch ~_____~) oooh and that it'd be 1000 to replace if i had to. Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 13, 2009 Share Posted August 13, 2009 are you sure you are having issues? maybe you're just getting used to it and all of the sudden you are thinking about the pedal, kind of deal.. like i said..it is adjustable (i think)..so you can get it adjusted Link to comment Share on other sites More sharing options...
wnstn Posted August 13, 2009 Author Share Posted August 13, 2009 I'll let you take it for a test drive lol b/c its engaging very close to the top and i'm not feeling the bite as much --- Link to comment Share on other sites More sharing options...
JoeFromPA Posted August 13, 2009 Share Posted August 13, 2009 wnstn - since you are using kilometers, I'm assuming you are from the great northern region called Canada. I'm not sure about your warranty, but in the U.S. the warranty covers wear items including the clutch up to 3 years, 36,000 miles. Though I've still seen stories of dealerships saying that's not accurate. Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 13, 2009 Share Posted August 13, 2009 pm'ed you, winston ~ Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 13, 2009 Share Posted August 13, 2009 yeah, we are in canada. dealerships saying different things isn't out of the norm here too.. reminds me of management at work...always telling you something different. even if you ask your supervisor the same thing two days in a row. Link to comment Share on other sites More sharing options...
wnstn Posted August 14, 2009 Author Share Posted August 14, 2009 wnstn - since you are using kilometers, I'm assuming you are from the great northern region called Canada. I'm not sure about your warranty, but in the U.S. the warranty covers wear items including the clutch up to 3 years, 36,000 miles. Though I've still seen stories of dealerships saying that's not accurate. Hey Joe, Thanks for the heads up - I'll definitely look into it Yea, it'd be surprising if the clutch is done already at such an early stage, given I don't hard launch the car, etc. Perry - Pm'd Link to comment Share on other sites More sharing options...
spect2k Posted May 22, 2010 Share Posted May 22, 2010 what ended up happening with your clutch? I feel like my 08 spec B does the same. The clutch engagement point gets high as I've drive for a while. Link to comment Share on other sites More sharing options...
