johnnymack Posted August 2, 2009 Share Posted August 2, 2009 Here are the logs from today. Stock map, COBB catted turbo back w/ drop in K&N. Boost never went above 11.xx PSI...possible leak I believe. 8/23/09- Updated in post #14 Link to comment Share on other sites More sharing options...
johnnymack Posted August 3, 2009 Author Share Posted August 3, 2009 Help. Link to comment Share on other sites More sharing options...
rtbrjason Posted August 3, 2009 Share Posted August 3, 2009 Did you take the intercooler off by any chance? I would look for any disconnected vacuum lines around that or the wastegate/actuator. Link to comment Share on other sites More sharing options...
Razor Posted August 3, 2009 Share Posted August 3, 2009 This is sort of the problem I have too. It happened right after I went turboback + up ... strange, keep eachother posted! Link to comment Share on other sites More sharing options...
johnnymack Posted August 3, 2009 Author Share Posted August 3, 2009 Did you take the intercooler off by any chance? I would look for any disconnected vacuum lines around that or the wastegate/actuator. No. I haven't done anything to the car except install the Kartboy STS. Since the car came with a COBB turbo-back, I'll start at the turbo to DP connection and go from there. Car is slow as molasses... Link to comment Share on other sites More sharing options...
sschmelcke Posted August 3, 2009 Share Posted August 3, 2009 whats your elevation??? Link to comment Share on other sites More sharing options...
johnnymack Posted August 3, 2009 Author Share Posted August 3, 2009 whats your elevation??? Sea level. maybe 200-500ft. at times. Highest elevation in Mo. is 1200 ft. Link to comment Share on other sites More sharing options...
dease42 Posted August 3, 2009 Share Posted August 3, 2009 wow, that's gotta hurt, I'm sorry to hear that with my 05 GT, I was getting around 12, 12-1/2, max, with the stock map. Not sure what the "difference" would be, stock to stock, but in my (*still-learning*) opinion, the rest of the log looks pretty normal. Link to comment Share on other sites More sharing options...
johnnymack Posted August 4, 2009 Author Share Posted August 4, 2009 Anyone think I have a leak? Link to comment Share on other sites More sharing options...
Razor Posted August 4, 2009 Share Posted August 4, 2009 The best thing to do is to try troubleshooting yourself to help eliminate possibilities. Take off your intercooler, make sure your lines are all secured. If you had a leak (pre turbo") you would probably hear it or notice a difference. Check your throttle body to IC connection. Link to comment Share on other sites More sharing options...
johnnymack Posted August 4, 2009 Author Share Posted August 4, 2009 The best thing to do is to try troubleshooting yourself to help eliminate possibilities. Take off your intercooler, make sure your lines are all secured. If you had a leak (pre turbo") you would probably hear it or notice a difference. Check your throttle body to IC connection. Agreed. I just wanted someone to chime in and tell me what the max boost is on the car in sport # mode or where I can find the info. I want to get an answer before I start taking things apart. Link to comment Share on other sites More sharing options...
05lgt5spd Posted August 5, 2009 Share Posted August 5, 2009 maybe the up gasket is leaking causing your turbo not to spool enough Link to comment Share on other sites More sharing options...
BLKGT5 Posted August 5, 2009 Share Posted August 5, 2009 The log shows 0% Wastegate Duty Cycle = low boost Stock 05 MT Boost levels RPM/PSI - YOU 800 0.97 N/A 2000 6.19 N/A 2400 13.53 N/A 2800 13.53 6.6 3600 13.53 9.4 4000 12.95 9.7 4800 11.98 11.17 5200 11.6 11.17 5600 11.21 10.88 6000 10.63 N/A 6400 10.25 N/A 6800 8.51 N/A Link to comment Share on other sites More sharing options...
johnnymack Posted August 23, 2009 Author Share Posted August 23, 2009 The log shows 0% Wastegate Duty Cycle = low boost Stock 05 MT Boost levels RPM/PSI - YOU 800 0.97 N/A 2000 6.19 N/A 2400 13.53 N/A 2800 13.53 6.6 3600 13.53 9.4 4000 12.95 9.7 4800 11.98 11.17 5200 11.6 11.17 5600 11.21 10.88 6000 10.63 N/A 6400 10.25 N/A 6800 8.51 N/A Logged again. Zero wastegate duty cycles. Anyone have an idea? Did someone upload a map and zero them out so they wouldn't overboost on the COBB turbo back exhaust? Thats the only power mod done to the car. Map seems very conservative. Here's the log from today:romraiderlog_20090823_133701(1).csv Link to comment Share on other sites More sharing options...
testes1010 Posted August 24, 2009 Share Posted August 24, 2009 emailed you. Read the map using ECUFlash and sent it to me. Link to comment Share on other sites More sharing options...
johnnymack Posted August 24, 2009 Author Share Posted August 24, 2009 emailed you. Read the map using ECUFlash and sent it to me. Will do. Thanks. Link to comment Share on other sites More sharing options...
