legacysti05 Posted July 21, 2009 Share Posted July 21, 2009 I have called my dealer, to change the rims size form 17 >18 via Subaru Select Monitor. They don’t seem to know what they are doing. Are there any instructions that Subaru published? I have the Spec.B wheels already; I don’t want to mess up my mileage. They have stock tires on them{ Potenza RE-050A tires} I want to keep my speedometer accurate. The reason to have the dealer change the rim size with the Select Monitor. Please post comments on ride quality on Spec B wheels verse stock GT & Pictures of members that have completed. Location S Florida 2005 Legacy GT Please Help.. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted July 21, 2009 Share Posted July 21, 2009 The difference is not in the rim but more of the tire. Make sure when you do get it you get good tires. Try Fredbeans for the rims. I just ordered some parts today from them. Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted July 21, 2009 Share Posted July 21, 2009 Wait, what did you do? Instructions for what? Just buy a set of Spec.B wheels here for half the price. Link to comment Share on other sites More sharing options...
legacysti05 Posted July 21, 2009 Author Share Posted July 21, 2009 I have the Spec.B wheels already; I don’t want to mess up my mileage. Link to comment Share on other sites More sharing options...
jeepr Posted July 21, 2009 Share Posted July 21, 2009 Pictures? It would look like, uh, a spec B? Link to comment Share on other sites More sharing options...
legacysti05 Posted July 21, 2009 Author Share Posted July 21, 2009 Pictures? It would look like, uh, a spec B? Pictures of spec B rims on 2005 Obsidian Black GT Thanks D0WNxSH1FT Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted July 21, 2009 Share Posted July 21, 2009 I have the Spec.B wheels already; I don’t want to mess up my mileage. So your question is what size tires do you need to keep the mileage equal? Tirerack.com 2005 LGT OEM = 215/45/17 If you want 18's they say = 225/40/18 Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted July 21, 2009 Share Posted July 21, 2009 Pictures of spec B rims on black GT Might want to say what year Spec.B as they are different. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 21, 2009 Share Posted July 21, 2009 I will make it easy for you. Just put the wheels on the car and you will be fine. Make sure the tires are good and all the same. You should not worry. I was going to do spec b wheel on my 08 and I have a 2.5I, you will be OK. do not fear the all mighty SPEC B wheels ahahah. Link to comment Share on other sites More sharing options...
LIZARD Posted July 21, 2009 Share Posted July 21, 2009 Pictures of spec B rims on 2005 Obsidian Black GT Thanks D0WNxSH1FT **search is your friend** Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
LIZARD Posted July 21, 2009 Share Posted July 21, 2009 I don't think the Spec.B wheels will net you better mileage, I do know they will make yoo teH fasterer!! Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted July 21, 2009 Share Posted July 21, 2009 I don't think the Spec.B wheels will net you better mileage, I do know they will make yoo teH fasterer!! I think the issue is that a change in tire size could effect the dashboards readings. RPMs, MPH and Odometer readings change when you change the overall diameter of the wheels. Link to comment Share on other sites More sharing options...
Spec B Posted July 21, 2009 Share Posted July 21, 2009 i think the OP wants to know how to get the ECU to recognize the different size wheel/tire combo. Link to comment Share on other sites More sharing options...
VXCL Posted July 21, 2009 Share Posted July 21, 2009 yeah they can adj the ecu to change to the larger 18" size wheel but who cares. the bigger the wheel the less milage. your speedo will barely be off. my 235/40 18s are a good inch over my stock 215/45 17s and its barely noticable. when i sell the car it will have a couple 1000 less miles on it as well. ahahahaah. this is of course over 5-8 yrs of ownership though. oh yeah you can ride 2nd gear out longer as well. comes in handy for auto-x MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
naimouasta Posted July 21, 2009 Share Posted July 21, 2009 i went from stock 205/50/17 to 235/40/18. the speed odometer is actually more accurate now according to my gps. Link to comment Share on other sites More sharing options...
SCSpecB Posted July 21, 2009 Share Posted July 21, 2009 I don't think the Spec.B wheels will net you better mileage, I do know they will make yoo teH fasterer!! Yah you better make sure you switch to the 250mph speedo that comes stock on the Spec.B Link to comment Share on other sites More sharing options...
sethstil Posted July 21, 2009 Share Posted July 21, 2009 use one of the umpteen upsize/downsize calculators found on google - get the rubber to match the height and width of your 17" setup - and no ECU/speedo/tach adjustments needed. this is the easiest way to deal with it. Link to comment Share on other sites More sharing options...
rtbrjason Posted July 22, 2009 Share Posted July 22, 2009 ^ + 1 to this but it looks like he already has the oem tires on the wheels he got. As a side note.. The spec b wheels (08/09 at least) are really heavy. Not sure what you have on it now, but heavy wheels suck. You lose acceleration performance, braking performance and handling.. Link to comment Share on other sites More sharing options...
RJS5689 Posted July 22, 2009 Share Posted July 22, 2009 I will make it easy for you. Just put the wheels on the car and you will be fine. Make sure the tires are good and all the same. You should not worry. I was going to do spec b wheel on my 08 and I have a 2.5I, you will be OK. do not fear the all mighty SPEC B wheels ahahah. Haha, they are rather hefty though! Link to comment Share on other sites More sharing options...
legacysti05 Posted July 22, 2009 Author Share Posted July 22, 2009 Does anyone have a number of a subaru dealer that knows how to change the tire size in the ecu. So I can school my dealer. http://i103.photobucket.com/albums/m151/legacysti05/IMG_0230.jpg Camera phone Link to comment Share on other sites More sharing options...
legacysti05 Posted July 22, 2009 Author Share Posted July 22, 2009 http://i103.photobucket.com/albums/m151/legacysti05/2007_subaru_legacy_gt_sedan.jpg Link to comment Share on other sites More sharing options...
