Jimmy78 Posted July 19, 2009 Share Posted July 19, 2009 show me pics of how u installed ur xm radio unit in ur car Link to comment Share on other sites More sharing options...
Jimmy78 Posted July 20, 2009 Author Share Posted July 20, 2009 any1?? Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted July 20, 2009 Share Posted July 20, 2009 Ill get you a pic of my set up soon. Previous owner did it. But it sits in the cubby pod and is hooked into the stock head unit via a jazzymod. Link to comment Share on other sites More sharing options...
TPLGT Posted July 20, 2009 Share Posted July 20, 2009 Ill get you a pic of my set up soon. Previous owner did it. But it sits in the cubby pod and is hooked into the stock head unit via a jazzymod. Exact same setup. I have a Terk Commander in the cubby. We cut one of the moldings that came with it to take up the gaps between the unit and cubby. I ahve ti hooked into the jazzy...very nice set up. Been like this for 2+ years. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Jimmy78 Posted July 20, 2009 Author Share Posted July 20, 2009 yea i have a gauge pod in my cubby pod..looking where else would b a good spot to mount it so it looks clean Link to comment Share on other sites More sharing options...
recuomo Posted July 20, 2009 Share Posted July 20, 2009 Roady2 installed in the cubby. Link to comment Share on other sites More sharing options...
c-lo Posted July 20, 2009 Share Posted July 20, 2009 me too^^^ no pics though. some on here somewhere. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Jimmy78 Posted July 20, 2009 Author Share Posted July 20, 2009 any besides cubby pod hookup?? Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted July 20, 2009 Share Posted July 20, 2009 Really the best place to put it IMO. Honestly im taking mine out for gauges as soon as i can. Already turned off XM.... Have the casopolis pod and gauges waiting. Link to comment Share on other sites More sharing options...
peteyjr Posted July 20, 2009 Share Posted July 20, 2009 There is not a better place than the cubby to place an outboard XM tuner. I had the Audiovox XM roady II in there and it fit well and looked good as well too. another place is a small unit on the left side of the dash or over the ashtray (if you don't use it). I'll send pics soon if I can. Link to comment Share on other sites More sharing options...
Jimmy78 Posted July 20, 2009 Author Share Posted July 20, 2009 i was thinking ashtray if u got pics peter that would b cool if yah can Link to comment Share on other sites More sharing options...
eldiablo Posted July 20, 2009 Share Posted July 20, 2009 Attached my Roady xt to kuda base. My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
Jimmy78 Posted July 20, 2009 Author Share Posted July 20, 2009 el diablo how does that base mount to the side panel, double side tape screws suction cup? Link to comment Share on other sites More sharing options...
eldiablo Posted July 20, 2009 Share Posted July 20, 2009 here's a pic from my old set up showing side view... the base mounts to car using existing head unit screws located under trim piece. Remove trim, take out 2 screws, position base, re-install screws and trim. My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted July 20, 2009 Share Posted July 20, 2009 I have one of those waiting to be installed when i do my gauges. Doing the ipod there. Link to comment Share on other sites More sharing options...
Jimmy78 Posted July 21, 2009 Author Share Posted July 21, 2009 nicee wad kind of holder is that Link to comment Share on other sites More sharing options...
eldiablo Posted July 21, 2009 Share Posted July 21, 2009 The XM unit uses the mfr provided mount. In that old pic I had to craft an extension to make way for the ipod cable. Now that I'm using a harman kardon drive + play for ipod control, the XM is mounted flush to the kuda base. My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
keynon Posted July 22, 2009 Share Posted July 22, 2009 I installed an xm sportscaster in the place of the ashtray. I'll take some pictures today. Link to comment Share on other sites More sharing options...
keynon Posted July 23, 2009 Share Posted July 23, 2009 Wired to the cigarette lighter and to radio via jazzy mod Link to comment Share on other sites More sharing options...
AV8TORSADF Posted July 25, 2009 Share Posted July 25, 2009 Wired to the cigarette lighter and to radio via jazzy mod Keynon, what nav setup do you have? Is the nav the one that came with the car or is it after market? Thanks! Link to comment Share on other sites More sharing options...
Jimmy78 Posted July 25, 2009 Author Share Posted July 25, 2009 how do u wire the xm radio through the aux plug if the stock deck has 1? bc if u have to hard wire through ur antenna and stuff. Link to comment Share on other sites More sharing options...
keynon Posted July 26, 2009 Share Posted July 26, 2009 Keynon, what nav setup do you have? Is the nav the one that came with the car or is it after market? Thanks! The nav is a Garmin 660. I pulled the cubby out and built a wooden enclosure for it. Since it's wired to the cigarette lighter, it comes on with the ignition (so you never have to pull it out to turn it on). Link to comment Share on other sites More sharing options...
keynon Posted July 26, 2009 Share Posted July 26, 2009 how do u wire the xm radio through the aux plug if the stock deck has 1? bc if u have to hard wire through ur antenna and stuff. I used the Jazzy mod as my aux into the radio. (you'll have to search for it). It involves just under an hour of installation and works well. The xm will have a seperate antenna and you don't need to use a FM modulator. Link to comment Share on other sites More sharing options...
CzarDestructo Posted July 26, 2009 Share Posted July 26, 2009 http://members.cox.net/spedonabike/Legacy/DSC03379.jpg Link to comment Share on other sites More sharing options...
peteyjr Posted July 27, 2009 Share Posted July 27, 2009 By all means use some sort of Aux in mod when doing XM or sat radio. FM modulators ruin the sound . I did the soldering in mod before I went to real aftermarket head unit. Link to comment Share on other sites More sharing options...
