bsax14 Posted July 14, 2009 Share Posted July 14, 2009 i am at the fork in the road where i need to decide whether to rebuild my engine (EJ257) w forged pistons, rings, bearings, etc. or to buy a new short block. I was quoted about $3700 for the rebuild considering my case, rods and crank are in good condition. This is with all necessary labor. I could just buy a whole new block for around 2 grand as well, so im just weighing my options and would like an opinion from someone else.... Thanks Link to comment Share on other sites More sharing options...
atc5 Posted July 14, 2009 Share Posted July 14, 2009 Daily driver and staying at stg 2 get new block. Going bigger turbo get built block Link to comment Share on other sites More sharing options...
bsax14 Posted July 14, 2009 Author Share Posted July 14, 2009 will have the STI swap as well w/ injectors, pump, and TGV deletes. thanks im thinking the rebuild.... my block does have 85K miles.... Link to comment Share on other sites More sharing options...
rao Posted July 14, 2009 Share Posted July 14, 2009 Until someone finds an actual problem with your actual block I vote for keeping it Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
AWDxBOOST Posted July 14, 2009 Share Posted July 14, 2009 build it up, its really not all that hard or expensive if you can do it yourself but if not, it'd still be worth it to get someone else to do it imo Link to comment Share on other sites More sharing options...
