doogdog Posted March 11, 2005 Share Posted March 11, 2005 Just trying to get a consensus of where everybody's factory sub has been mounted. The idiot dealer put mine under the driver's seat, little to no clearance and it has been gouged by the underside of the seat. It seems logical that the sub shoulld be under the passneger's seat. Furthermore, the dealer made no attempt to hide the wiring harness under the carpat, there's a black harness for everyone to see plain as day. Maybe I'm being too critical, I'd like to see where everyone else has their's. Thanks, Rick Link to comment Share on other sites More sharing options...
rc0032 Posted March 11, 2005 Share Posted March 11, 2005 Just trying to get a consensus of where everybody's factory sub has been mounted. The idiot dealer put mine under the driver's seat, little to no clearance and it has been gouged by the underside of the seat. It seems logical that the sub shoulld be under the passneger's seat. Furthermore, the dealer made no attempt to hide the wiring harness under the carpat, there's a black harness for everyone to see plain as day. Maybe I'm being too critical, I'd like to see where everyone else has their's. Thanks, Rick The idiot was right. It goes under the drivers seat. Black harness might is blue you are lucky Link to comment Share on other sites More sharing options...
mwiener2 Posted March 11, 2005 Share Posted March 11, 2005 Yeah that's the way it's supposed to be...you got lucky with the black harness.....alot of us have a bright blue harness My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
feersum dreadnaught Posted March 11, 2005 Share Posted March 11, 2005 yup, bright blue, and under the driver's seat Link to comment Share on other sites More sharing options...
goneskiian Posted March 11, 2005 Share Posted March 11, 2005 Bright blue here too, and, yup, under the drivers seat! Hmm, wonder if they got complaints about the blue and changed it to black. Maybe they could do that with mine. -Ian Link to comment Share on other sites More sharing options...
boostsr20 Posted March 11, 2005 Share Posted March 11, 2005 Bright blue and this thing is next to worthless. With worthless beating it out in a few categories..... Link to comment Share on other sites More sharing options...
PGT Posted March 11, 2005 Share Posted March 11, 2005 So, the harness is not under the carpet? I installed mine myself....took the seat out and ran the harness properly UNDER the carpet. It took me 60-75 minutes TOPS. Take it back to the dealer and get them to run it properly. Link to comment Share on other sites More sharing options...
sduford Posted March 11, 2005 Share Posted March 11, 2005 Yes the harness is supposed to go under the carpet, there is even a pre-made opening for it. But it seems most dealers improperly install them. I had to get my dealer to re-install mine. Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
doogdog Posted March 11, 2005 Author Share Posted March 11, 2005 I paid some $250.00 for the install at the dealer, they pulled the car in to install the sub as I pulled to take delivery of my new car. Mind you I had sign the P & S agreement a week prior. They take way too long hooking it up and make me late for an appointment I had. About a week later I decide to figure out how to disasemble my dash for my Scanmaster 3 install and XM install. The dealer forgets to put in a screw on the radio and pits a mismatched screw holding on the side trim. At this point I also notice the harness in sot run under the carpet. The dealer said something about the bracket not fitting properly and they had to modify it to fit. I guess at this point I'm just venting, boy they piss me off. I will take the time and do it properly, thanks for the info guys. Rick Link to comment Share on other sites More sharing options...
DSattler Posted March 11, 2005 Share Posted March 11, 2005 Mine is under the driver's seat, a small piece of blue wiring can be seen between the shift console and the seat, and the sound quality is good. It definitely extends the bottom end a bit, though you won't win any volume contests with it. Link to comment Share on other sites More sharing options...
Legacy05 Posted March 11, 2005 Share Posted March 11, 2005 Bright blue here too, and, yup, under the drivers seat! Hmm, wonder if they got complaints about the blue and changed it to black. Maybe they could do that with mine. -Ian I wouldn't think its an issue if its installed right ... mine comes from under the carpet ... Link to comment Share on other sites More sharing options...
CDubbs Posted March 11, 2005 Share Posted March 11, 2005 Its under the drivers seat because of the issues with the weight sensor under the pass seat for the on/off switch on the pass airbag. Remember if you pull your pass seat youre supposed to get it recalibrated. Could be wrong though. (Wifes wrx wagon has it under pass) No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
wayne53 Posted March 13, 2005 Share Posted March 13, 2005 it's blue, and it under the drivers seat. -Tyler Link to comment Share on other sites More sharing options...
otoc Posted March 14, 2005 Share Posted March 14, 2005 I just installed mine, the harness cover was blue and it went under the drivers seat. I ran the wire under the carpet and pulled it out of the cutout that is already there (as described earlier). I didn't have to remove the seat. I just pulled the bolt that has to be removed to lock down the subwoofer bracket. After pulling that rear bolt on the driver's seat I put a screw driver handle underneath (to hold it up) and it gave the clearance needed to run the harness under the seat. Use a long handled screwdriver to push the harness down between the console and the seat and you should be able to reach it from under the seat (through the hole in the carpet). Long fingers help. There's a change over to the Subaru method for you dealer installed guys, so I would have the dealer do it to get the harness under cover (pretty lame with it showing). The passenger seat is where the shock sensor mounts, btw. No room for both... Link to comment Share on other sites More sharing options...
