eamiller Posted March 10, 2005 Share Posted March 10, 2005 Well, I finally got around to installing my Panavise mount for my SkyFi.. I've attached pictures for all to see.. Still haven't installed the modulator yet, but I should be getting the last of the antenna connector parts I need soon (and some warm weather would be nice).. Sorry for the quality, it's an overcast (snowing) day and little light was available.. B&W looked better than the color.. Link to comment Share on other sites More sharing options...
axis008 Posted March 12, 2005 Share Posted March 12, 2005 That's pretty cool! Curious, but have you thought of placing it in your cubby hole? -ben Link to comment Share on other sites More sharing options...
eamiller Posted March 12, 2005 Author Share Posted March 12, 2005 SkyFi is wayyy to big for the cubby, with it's clunky cradle and all.. I think someone around here even measured the Roady and it was a little on the big side.. The only unit I know of that fits is the Commander style of radios.. I've had my SkyFi for like 2 years, since I work for Delphi and get a big ol' discount on the unit.. The PanaVise fits like a dream, there's even a notch in the climate control which allows it to squeeze through the seam.. Link to comment Share on other sites More sharing options...
firedawgs Posted March 12, 2005 Share Posted March 12, 2005 Here is my roady2 install. http://img202.exs.cx/img202/1504/dsc00525jpg22qr.jpg Updated my vBGarage: Link to comment Share on other sites More sharing options...
boostsr20 Posted March 13, 2005 Share Posted March 13, 2005 How involved is it to wire the Skyfi into the radio? I used to do all my own Car audio stuff but haven't touched anything in a couple years. Is it pretty tough or what? Link to comment Share on other sites More sharing options...
eamiller Posted March 13, 2005 Author Share Posted March 13, 2005 The hardest part is the fact that Subaru has decided to use a Hirose connector for the antenna instead of a traditional Motorola antenna connector.. Once you have either tapped into the wire or obtained the parts to make 2 conversion cables, it's rather simple to wire it in. For the best quality (for the stock stereo) use an FM modulator. There's quite a few threads around here on the process and parts needed. The easiest solution is to use an FM broadcaster, but the quality is much lower. Link to comment Share on other sites More sharing options...
c-lo Posted March 15, 2005 Share Posted March 15, 2005 so it sounds like what you are saying is using an fm modulator will give you better sound quality then perhaps using the skyfi2? This has been a subject I have posted on before, know people may be getting sick of the question, but any help would be greatly appreciated. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
eamiller Posted March 15, 2005 Author Share Posted March 15, 2005 FM modulator gives the best sound quality, short of directly connecting to the internals of the radio (been done, PITA). FM transmitters are acceptable for short term, if you can stand the hiss and general lack of dynamic range. I would only get the SkyFi2 if I really wanted the better display, recording, and stock/sports ticker. Also, the SkyFi2 has the new tuner chipset, so it's faster tuning and less prone to dropouts. Link to comment Share on other sites More sharing options...
