Salle071 Posted July 7, 2009 Share Posted July 7, 2009 My user manual calls for NGK FR5AP-11 (double platinum) Local parts shop is listing NGK BKR5EIX-11 (iridium) Which one is better or proper part? Latter one is in stock, first one hard to get. Both seem the same heat range. Any ideas? Thanks Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 9, 2009 Share Posted July 9, 2009 I would call a Subaru Dealer and ask what they stock odds are the NGK are close in price btwn the parts store and the Subbie parts depo. But my gut would follow the manual that way if there is an issue the dealer cant say you didnt follow instructions etc. I think the stock plugs are about $12.50 USD/a piece. They both are good plugs btw Link to comment Share on other sites More sharing options...
N.sane Posted July 9, 2009 Share Posted July 9, 2009 FR5AP-11 is the proper part, our cars use platinum. Iridium is used by the GT Link to comment Share on other sites More sharing options...
06Limited Posted July 10, 2009 Share Posted July 10, 2009 Checkout sparkplugs.com Link to comment Share on other sites More sharing options...
smushybrain Posted July 11, 2009 Share Posted July 11, 2009 I have the BKR5EIX-11 NGK Iridium plugs waiting to go on my car. They should be the same as the OEM plugs aside from the Iridium tips instead of Platinum. I had the same plugs on my previous Nissan Altimas and I figured I'd give them a try on my Legacy, too... Link to comment Share on other sites More sharing options...
mwiener2 Posted July 11, 2009 Share Posted July 11, 2009 no reason to go iridium on the 2.5i My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Salle071 Posted July 12, 2009 Author Share Posted July 12, 2009 BKR5EIX-11 is the one they list for either car and is in stock. The former they have not had for a while. My current plugs have 50,000km on them, but engine runs like a clock. Should I be changing them anyway? In three days it goes to dealer for tranny flush. I'll ask how much they want for plugs. Iridiums are $10 CDN a piece. Link to comment Share on other sites More sharing options...
smushybrain Posted July 12, 2009 Share Posted July 12, 2009 Iridium plugs last a little longer, which is probably their main benefit. I noticed a slightly smoother idle with them on my Altimas, too. Other than that, there's not too much of a benefit to the iridiums, though. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 16, 2009 Share Posted July 16, 2009 I say use the stock plugs, they have worked great so far, so why change it up. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 16, 2009 Share Posted July 16, 2009 Yeah some claim copper are the best others platinum etc etc. I would run what the book calls for but it is your cash. They wont make your car run any better than it does now. But i change my plugs every 15K and use the FR5AP-11 NGK plug Link to comment Share on other sites More sharing options...
ouch1011 Posted July 20, 2009 Share Posted July 20, 2009 The Iridiums work better for cars that experience high combustion chamber temps [like those running forced induction or nitrous]. Platinum plugs have been known to sometimes melt or wear very quickly under those conditions. However, platinum plugs would work fine for the n/a model. Personally, I'd just use the MUCH cheaper NGK v-power copper core plugs. They usually run around 2 bucks per plug, and while they don't last as long as platinum/iridium plugs, I don't suggest running plugs much longer than 30-40k anyway especially on aluminum heads. I've seen too many that gall the threads in the head and end up stripping them out when the plugs are finally removed. This is much less likely to happen if the plugs are replaced earlier. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 20, 2009 Share Posted July 20, 2009 Stock plugs = win Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 20, 2009 Share Posted July 20, 2009 Good point with the changing of the plugs more often. STOCK FTW but I wonder how a comparable plug would fair???? FTL??? IDK I wouldnt put Autolites in a subbie Maybe Bosch but NGK as a first consideration oh and beer or spirits Link to comment Share on other sites More sharing options...
Kelvrick Posted July 20, 2009 Share Posted July 20, 2009 I put the GT iridiums in mine just so I wouldn't have to change as often. My Outback Link to comment Share on other sites More sharing options...
mwiener2 Posted July 21, 2009 Share Posted July 21, 2009 pulse plugs... that's where it's at My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ouch1011 Posted July 21, 2009 Share Posted July 21, 2009 Bosch plugs are actually notoriously poor quality. Every drivability tech I've ever worked with refused to use Bosch plugs. I've used NGK plugs exclusively in every car I've ever had as well as most of the other cars I've worked on, including V-power, G-power [platinum] and Iridium, and I've never had a problem with any of them. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 27, 2009 Share Posted July 27, 2009 ^^^Agreed Link to comment Share on other sites More sharing options...
