LGTspecB1657615261 Posted June 5, 2009 Share Posted June 5, 2009 I have attached a Learning view screenshot from a friend's car. 2003 WRX MT He put MBC on years ago increasing the boost (16 psi maybe?) Bone stock otherwise, and has been that way for a while. No tuning. I used Learning View to pull a recent CEL code for him, and this is what came up (see attached). I am still learning myself, so I would like to ask what is everyone's opinion of what they see? I think he should go back to stock EBCS and find an open source stg 1 map if there is one out there. Or pony up $150 and have Infamous create a map for him using just logs. With just stage 1 you can probably get a decent eTune without a WB AFR. Thoughts? Link to comment Share on other sites More sharing options...
rtbrjason Posted June 5, 2009 Share Posted June 5, 2009 Uh, get him a tune!? Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted June 5, 2009 Author Share Posted June 5, 2009 I found an OS stg 1 map floating around that supposedly will work with his ECU, the map code ends in 400L. For some reason I could not pull the stock ROM with ECUflash. Not sure why, my definitions are up to date. So for right now, I can't even test the map out if I wanted to. Of course it would also require that I hook up his stock ECBS back up. Link to comment Share on other sites More sharing options...
spec.b Posted June 6, 2009 Share Posted June 6, 2009 If he's running an 03 WRX, you need the little green jumper thingies... (yes that is the technical term) Link to comment Share on other sites More sharing options...
NSFW Posted June 6, 2009 Share Posted June 6, 2009 That's not a healthy car, the ECU is pulling lots of timing to limit detonation. And since it thinks he just got a tank of crap gas, it's going to continue adding timing, knocking, pulling timing, and so on, in hopes that the problem goes away on its own. But it won't. He needs to dump the MBC or get a tune. Link to comment Share on other sites More sharing options...
MindzEyeWRX02 Posted June 6, 2009 Share Posted June 6, 2009 OWN3D, by a MBC. lol. get it tuned. up the boost using a tune, not a controller unless you cant reach target boost with a tune. he would have had a safer setup if he just went to stage 2. Link to comment Share on other sites More sharing options...
Infamous1 Posted June 6, 2009 Share Posted June 6, 2009 That looks very bad. Link to comment Share on other sites More sharing options...
Ridgeracer Posted June 7, 2009 Share Posted June 7, 2009 Never really seen both positive and negative correction together. Is that normal for 03 WRXs running that ROM?? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Infamous1 Posted June 7, 2009 Share Posted June 7, 2009 Never really seen both positive and negative correction together. Is that normal for 03 WRXs running that ROM?? That is very common once the IAM is no longer 1.0000 or in this case 16. Link to comment Share on other sites More sharing options...
Ridgeracer Posted June 7, 2009 Share Posted June 7, 2009 I see...Cool beans Shamar. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
