FPerron Posted May 24, 2009 Share Posted May 24, 2009 I replaced my seats with aftermarket units and now have the red "Airbag" light to the left of the steering column. Is there a way to get rid of it? I also have the "Passenger Airbag Off" light - which, of course, is normal with nothing in the passenger seat. During state inspection, does someone actually sit in the seat to see if the light goes out? Thanks Link to comment Share on other sites More sharing options...
OhBe1 Posted May 25, 2009 Share Posted May 25, 2009 I'll kick off the responses with my assumption that all it takes is the right resistance placed in each of the airbag connectors, just like for steering wheel bags. 3 ohms seems common, at least for wheels. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
rao Posted May 25, 2009 Share Posted May 25, 2009 Remove the bulb Of course the large rear wing would throw off the weight sensor calculations in the passenger seat anyways....... Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
