06GRPLGT Posted November 9, 2015 Share Posted November 9, 2015 Busted isn't the right word. Scratched up is more like it. If you're seriously interested I can take some pics. It's in excellent condition overall. Link to comment Share on other sites More sharing options...
FlipNap Posted December 10, 2015 Share Posted December 10, 2015 Finally getting around to installing the rear JDM bumper. I had the shop trim down the bumper beam to fit. Should have the car back tomorrow Link to comment Share on other sites More sharing options...
FlipNap Posted December 13, 2015 Share Posted December 13, 2015 Got the car back together, wired up the JDM headlights, and threw on the roof rack. Next on the to-do list is a detail... Link to comment Share on other sites More sharing options...
Drift Motion Posted December 14, 2015 Share Posted December 14, 2015 and convert the JDM RHD headlights to LHD pattern Link to comment Share on other sites More sharing options...
FlipNap Posted December 14, 2015 Share Posted December 14, 2015 Yup, the headlights are converted for LHD. Nice thing is I didn't have to bake the JDM headlights. Link to comment Share on other sites More sharing options...
valleylegacy Posted December 14, 2015 Author Share Posted December 14, 2015 Very nice. Link to comment Share on other sites More sharing options...
famaya26 Posted March 16, 2016 Share Posted March 16, 2016 So how much are JDM Rear Bumpers running for? Link to comment Share on other sites More sharing options...
famaya26 Posted March 16, 2016 Share Posted March 16, 2016 Sorta got mine painted. lol http://uploads.tapatalk-cdn.com/20160303/8080d59c8ac6c7a273e0052640758059.jpg Link to comment Share on other sites More sharing options...
HKC-speed.com Posted March 17, 2016 Share Posted March 17, 2016 Hi guys, I've noticed our name mentioned a few times on this thread, here is what we have in stock and ready to ship - thanks for everyone's support !! Spec B Front Conversion w/ Fogs and more http://www.hkc-speed.com/wp-content/uploads/2016/03/10.jpg Details here: http://legacygt.com/forums/showthread.php/fs-jdm-spec-b-front-bumper-conversion-others-250921.html K2 Front Conversion w/ Fogs and brackets http://www.hkc-speed.com/wp-content/uploads/2015/09/k2gear-blbp-front-bumper-conversion47227a-1.jpg Details here: http://legacygt.com/forums/showthread.php/fs-jdm-k2-front-bumper-conversion-247983.html Link to comment Share on other sites More sharing options...
JuicyJDM Posted March 24, 2016 Share Posted March 24, 2016 Anyone know where to get the JDM aero side skirts from? Also, will the JDM spats fit over the aero package (rear valance) if this is the only option to get them? Link to comment Share on other sites More sharing options...
06GRPLGT Posted March 28, 2016 Share Posted March 28, 2016 Liberal Albero bumper up for sale. Get it while it's hot. http://legacygt.com/forums/showthread.php/ca-liberal-albero-jdm-bumper-linked-pics-251321.html Link to comment Share on other sites More sharing options...
WRX USA Posted March 28, 2016 Share Posted March 28, 2016 Here it is... Most Complete Retrofit List: Sedan 05-07 (Rev A-C) JDM Bumper Bumper Beam (or cut USDM beam) Bumper Brackets Shock Absorber Fender Liners (or cut original liners) Fog Lights (JDM brackets, DIY brackets, or entire assemblies cut out of USDM bumper.) Sedan 08-09 (Rev D-F) JDM Headlights (Optional: Headlight leveling switch and plugs. Plugs available at Toyota or Lexus dealer.)(Requires rewiring and soldering skills depending on which lights you want to use and because the JDM headlight wiring connectors are different from USDM.) Fenders Bumper Bumper Beam (or cut USDM beam) Bumper Brackets Shock Absorber Fender Liners From Leke on the Rev D-F headlight wiring: For the Rev D-F lights, the best thing to do is to take a battery harness and use the OEM (USDM) plugs as your means to activate the relay. The other (the wires that run to the headlights) terminals can then be modified to include the JDM plugs. This method requires more work, but the overall result is much cleaner. You could easily permanently modify your stock wiring to work with the JDM lights. But doing this will make life difficult if you ever want or need to go back to a USDM setup. The other part that requires thinking is the parking light and turn signal. On the JDM light they're different bulbs, but the USDM turning/parking light socket is integrated into one plug. Easiest thing to do here is to use the USDM plug as it is, but solder new wiring to the terminals where the bulb would sit. This requires a steady hand, as there is visually no space to work with. But, your parking light and turn signals would function as they would on the stock car. If you ever want to go back to a USDM setup, all you need to do is source a new turn signal/parking light socket. Someone please add this to the first post!!! In respects to 08-09, is it 100% confirmed that the USDM hood works? I understand that an OBXT will also need a LGT aluminum hood. For reference. http://i672.photobucket.com/albums/vv87/JoshEAllen/968AAF61-BE81-4195-9123-F4BA898BEE56.jpg Link to comment Share on other sites More sharing options...
madrig Posted March 30, 2016 Share Posted March 30, 2016 Link to comment Share on other sites More sharing options...
famaya26 Posted March 30, 2016 Share Posted March 30, 2016 [attach]227430[/attach] What are those on the side??? Link to comment Share on other sites More sharing options...
madrig Posted March 31, 2016 Share Posted March 31, 2016 extension to match wider fenders , will be bond and blend on to bumper later Link to comment Share on other sites More sharing options...
famaya26 Posted April 1, 2016 Share Posted April 1, 2016 Where did you get them? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
madrig Posted April 2, 2016 Share Posted April 2, 2016 this is home made , when i did the extension i also shaped the lip , but i m not decided yet i wil use this lip . i can seperate the lip from the extension side , was more easy to mold all one piece at the time Link to comment Share on other sites More sharing options...
famaya26 Posted April 2, 2016 Share Posted April 2, 2016 That's awesome Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
famaya26 Posted April 17, 2016 Share Posted April 17, 2016 http://uploads.tapatalk-cdn.com/20160417/f8b4a59606b67b26043996f62c90c6dc.jpghttp://uploads.tapatalk-cdn.com/20160417/34d64a50c8729c5a526c29098cd434ae.jpg Will eventually order fenders and headlights so I can install this one. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Hanger Posted April 18, 2016 Share Posted April 18, 2016 on snap, that's sexy ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 18, 2016 Share Posted April 18, 2016 I thought you already had a JDM bumper Famaya? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
famaya26 Posted April 18, 2016 Share Posted April 18, 2016 I thought you already had a JDM bumper Famaya? I do. Found this one, complete kit (bumper, grill, fogs, fog covers, bumper beam) for dirt cheap. Link to comment Share on other sites More sharing options...
famaya26 Posted April 18, 2016 Share Posted April 18, 2016 http://uploads.tapatalk-cdn.com/20160418/fefb3ae45fe8f7d8519a47b098b55670.jpg Lip also included. Once I'm able to order fenders and headlights I will swap everything over. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
madrig Posted April 18, 2016 Share Posted April 18, 2016 what a great buy ! you got the deal of the year !! Link to comment Share on other sites More sharing options...
Shogun506 Posted April 19, 2016 Share Posted April 19, 2016 Famaya your car is a SWP right? I might be interested in your former JDM bumper if it looks like the Spec B one HKC has for sale.. Link to comment Share on other sites More sharing options...
