darkside Posted May 7, 2009 Share Posted May 7, 2009 Hey does any body know where i can buy a headlight halogen replacement..I cleared out lights and one bulb went bad.. If i tap the light it kicks in sometimes..Subaru is out of stock, has to be ordered.. Does anybody know part # or website that sells these or if discount or advance auto parts sell these. Its the center one with the chrome ring around it.. Thanks I need one for going out tonight, dont want to get pulled over.. Link to comment Share on other sites More sharing options...
cseagle08 Posted May 7, 2009 Share Posted May 7, 2009 it should have a number like 9005 or 9006 or something on it. should be at advance / auto zone / pep boys / o'reilly's, etc etc. I could be wrong, but you could call around really fast and find out. Link to comment Share on other sites More sharing options...
darkside Posted May 8, 2009 Author Share Posted May 8, 2009 Thanks, but After 3 hrs of taking the F---ing light off and on, go the stupid bulb out..I found out it is a H7 sylvania model. Got at discount for 15.00. You cant really get bulb out unless you take light off..Almost imposible to do with light on car.. There is a crappy metal clip with screw, that broke holding halogen bulb..If you ever do this be careful. The plastic piece that hold clip broke, very brittle.. Had to make a gehto paper clip bracket to hold in place. And dont touch bulb will make it wear out premature.. Well that definitely took more than 5 minutes.. But I got light.. Seeya Going Out. Peace Link to comment Share on other sites More sharing options...
slimjoe Posted May 8, 2009 Share Posted May 8, 2009 You'll get used to it soon enough. I can't count the number of times I've changed my front low beams. I think I've got it down to just a couple of minutes per side. Just unscrew the backing, unclip the socket, swap bulbs, get the wire around the bottom of the metal clip and put the socket back into the housing. Easy! Link to comment Share on other sites More sharing options...
OhBe1 Posted May 10, 2009 Share Posted May 10, 2009 By "unscrew the backing" you mean "peal off the rubber", right? No screws should be removed to change out a headlight bulb. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
LGT Dave Posted May 10, 2009 Share Posted May 10, 2009 By "unscrew the backing" you mean "peal off the rubber", right? No screws should be removed to change out a headlight bulb. I think he's talking about taking off the dust cover. Link to comment Share on other sites More sharing options...
