bnguyenbb6 Posted May 1, 2009 Share Posted May 1, 2009 So I was bored in my Art History class today and started researching what it would take to fab a brake duct leading air from the fog light area to the fender well (ie. BMW E36 M3 brake ducts). I was looking at SCCA Solo rules to make sure that it wouldn't be a modification that would be "illegal" in my class and ran across this: E. Fenders may not be cut or flared but the inside lip may be rolled to gain additional tire clearance. Flares that are part of body kits may be attached to the stock fenders. Plastic and rubber wheel well splash shields may be modified for tire clearance and to accommodate a rolled inside fender lip. The intention is to permit fitting the maximum allowable tire size, and the modifications may serve no other purpose (e.g. air intake, brake ducts, etc.). No other changes to the stock fenders or wheel wells are permitted.and then read this: C. Air ducts may be fitted to the brakes, provided that they extend in a forward direction only, and that no changes are made in the body/structure for their use. They may serve no other purpose.So the splash shield cannot be cut, so the only way to fab them is to have an existing hole, which defeats the purpose of having a splash shield in the fender(for OEM purposes). I don't see why there would be a hole in the splash shield unless you had an OEM brake duct, but then why would you need to fit an air duct? Do I just have a case of reading comprehension failure? No brake ducts for me? Seriously though, can anyone clear this up? Link to comment Share on other sites More sharing options...
JSaladino Posted May 1, 2009 Share Posted May 1, 2009 *subscribe* Link to comment Share on other sites More sharing options...
bluesuby Posted May 1, 2009 Share Posted May 1, 2009 Is it possible to install a brake duct under the bodywork and bring the airflow up from below the splashshield? Link to comment Share on other sites More sharing options...
Xenonk Posted May 2, 2009 Share Posted May 2, 2009 you can install the hoses up and around.. but since you are autocrossing, why on earth do you need brake ducts?? Seems to me you are reading the Solo2 rules. if you are thinking of doing track days, i would just yank out the fender liner (most race cars do this anyways unless (again) specified by their rules. Remember, these rules were developed for ALL cars that are within that class. So if you happen to be the car that doesnt have fender liners, lucky you. That's how the rules work overall: Some cars can take advantage of the rules while others have to be limited by them to even out the playing field. Keefe Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 2, 2009 Author Share Posted May 2, 2009 Yeah I do understand its overkill for AutoX. HPDE's and track days were sort of my worry. I have the resources to easily fab up ducts(abs plastic). It was more of a "if you can, why not?" type of thing. As for the rules, what is the difference? I was reading the rules off this link http://cms.scca.com/documents/Solo_Rules/2009_Solo_Rules.pdf Link to comment Share on other sites More sharing options...
Th3Franz Posted May 4, 2009 Share Posted May 4, 2009 Brake ducts are allowed so it shouldn't matter for your classing for autocross. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
whitetiger Posted May 4, 2009 Share Posted May 4, 2009 I wouldnt put brake ducts in a autox car. I have enough trouble getting heat in to my pads during an autox. a track car though is a different story than an autox car. Link to comment Share on other sites More sharing options...
