BillyJoe Posted April 24, 2009 Share Posted April 24, 2009 I have done some research on what to do with the EGT sensor "location" on my Invidia Catless up-pipe. I have decided to not use the OEM sensor, but instead to plug it with what people have been using on this forum, an oil drain bolt/plug. From what I've read, the correct size for my application would be M12X1.25. However, when I went to the local Autozone to pick up the oil drain plug in that size, I can only hand tighten it about 1/3 of the way down. I didn't however use a wrench to try to work it in more, since i didn't want to strip/force the bolt into my up-pipe. What i want to know is, do I have the right size? and Is it normal to not be able to hand-tighten down to bolt any further than about a 1/3 of the way? (for those who have already done this mod, what were you experiences?) I am having the stage 2 components installed tomorrow at a subaru dealer, so maybe they'll have something there. Thanks ahead of time for your help! Stan Link to comment Share on other sites More sharing options...
rao Posted April 24, 2009 Share Posted April 24, 2009 Spark plug size - M18x1.5 Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
BillyJoe Posted April 25, 2009 Author Share Posted April 25, 2009 sweet...thanks Rob, i'll check it out tomorrow. Link to comment Share on other sites More sharing options...
GTTuner Posted April 27, 2009 Share Posted April 27, 2009 I think rao is thinking of the 02 sensor size. It is def 12mm but not sure if it is 1.5 or 1.75 pitch thread. The last one of those I installed did the same thing, after three turns it was very tight. Link to comment Share on other sites More sharing options...
rao Posted April 27, 2009 Share Posted April 27, 2009 I was talking about the 02 sensor, not the EGT sensor Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
BillyJoe Posted April 28, 2009 Author Share Posted April 28, 2009 Yeah you're right, I do believe the EGT sensor in the up-pipe is 12mm. I would know for sure but i didn't end up going stage 2 this past weekend, it was getting late after my TGV deletes install, so i told the mechanic to go home and enjoy his saturday. So it's next week to go stage 2 for me. So i was not able to check if my 12mmX1.25 drain plug will fit right. At least we know its 12mm, now let's hope its 1.25 pitch thread or 1.50, because i can find drain plugs for those sized easily. I'll let you know what i find out. Thanks for your responses! keep em coming! Link to comment Share on other sites More sharing options...
BillyJoe Posted May 11, 2009 Author Share Posted May 11, 2009 FYI, the size of the plug for the EGT sensor on an Invidia UP catless is M12 X 1.5 Now the search continues for the right length! Thanks for all your responses. Link to comment Share on other sites More sharing options...
FPerron Posted May 12, 2009 Share Posted May 12, 2009 It's also important to use a plug that's made from close to the same alloy as the UP. Otherwise, the plug and the pipe will expand at different rates and the plug will blow out. Ask me how I know:redface: Link to comment Share on other sites More sharing options...
caramall2 Posted May 12, 2009 Share Posted May 12, 2009 This might not be your case, but for others.... If you're talking the smaller EGT bungs (e.g. they're about 3/8" wide at the opening).... EGT sensors are usually 1/4" NPT (Nat Pipe Thread taper)...this is a special plug that tapers down (not a regular bolt, etc.). I know because I struggle with this as well. Go to a good bolt place and tell them you need a 1/4" NPT pipe plug (they're about 1/4" long or so). NPT is used on piping for heating systems, etc, from what I understand....like your black iron piping you see in a boiler room. The threads actually "taper" a bit so as you tighten they get to a point you can't tighten any more. Link to comment Share on other sites More sharing options...
jus2phast4uLGT Posted July 24, 2009 Share Posted July 24, 2009 great post guys thanx..i just ordered a greddy up-pipe with egt "dur"..shoulda got it w/ out the egt bung since i hear the egt probes can blow out (if installed) and blow a turbo :/ Link to comment Share on other sites More sharing options...
croll326 Posted April 21, 2010 Share Posted April 21, 2010 I called Invidia today and from what I could understand the person I talked to said M12x1.5 but I asked him what type of thread it was and he was clueless. I think www.mcmaster.com would have something. From what I am finding 1.5 thread pitch is not available in a stainless steel bolt, I am pretty sure the UP is 304 stainless....ill keep looking Any worries using a zinc plated bolt or plain steel that will rust? I am thinking after I put the bolt in I will have the bolt welded in at a local fab shop. Why not just get a M12x1.5 set screw. It doesnt have a head on it so if you get a short one you can just tighten in as far at it will go before it seats itself in the bottom of the hole. http://www.mcmaster.com/#set-screws/=6qz0v2 Link to comment Share on other sites More sharing options...
croll326 Posted May 2, 2010 Share Posted May 2, 2010 I went to a local parts store today and came away with nothing. A 1/4" NPT plug wouldnt even thread in. The M12's only go in about 3 threads then bind. What do I do now? Is it ok to take a M12 and thread it in as far as possible and let it be? I was thinking about getting the hole welded shut instead of using a bolt. Thoughts? Link to comment Share on other sites More sharing options...
croll326 Posted June 2, 2010 Share Posted June 2, 2010 I installed the up pipe with the EGT sensor and am having second thoughts. I want to plug the hole! Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 13, 2013 Share Posted August 13, 2013 I know this is an old thread but I am getting conflicting sizes, it says M12x1.5 but here it says M12x1.25... 12mmx1.25 From: http://legacygt.com/forums/showthread.php/size-egt-sensor-up-pipe-39150.html And has anyone found a good Stainless Steel bolt to use? Thank you. Link to comment Share on other sites More sharing options...
