Cloudy Headlights After LED Mod
absolutsnwbrdr
OP if all else fails buy one of the kits that they sell to restore headlights on older cars. I paid 12.99 at auto zone and polished my headlights on a 95 dakota. They came out really good and could save u full replacement cost on your headlights.
Good luck
  • Replies 58
  • Created
  • Last Reply
Take a look at Meguiar's PlastX plastic and glass polisher.
Do some sanding with 100, 200, 500, 1000, 2000 sandpaper, and then rub a bit of the polisher on that and rub it around. I used that to clear my front emblem badge that was all cloudy and it worked pretty well.
Give it a shot. Then there is another thread on these forums where a cheap aftermarket replacement headlight was brought up. The quality is still up in the air; someone bought them, and cracked them open in the oven, and apparently a year later something was bubbling up or whatnot, but still, much cheaper than OEM replacements. Might want to take a look.
http://legacygt.com/forums/showthread.php?t=109582
Do ask darkoblivion has suggested.
Wet sand starting at 300 grit going in a up and down motion then switching to a right to left motion (DO NOT GO IN CIRCLES)
Do about 5 rounds of switching off going each way for about a minute each then go up to a 600 grit and repeat.
Ass you take the contaminent off the surface you will feel it getting much easier to move the paper across. Be sure to always keep diping the paper in a bucket of water to keep it plenty wet.
Pick up some Plastix and once you've done the 2000 you'll notice they are clear already but the plastix will finish them off. Let them sit for about an hour or 2 fully open to allow the plastix to fully cure.
Reassemble and TA DAH!!!!
yeah i just got some PlastX for myself at autozone like 15 minutes ago, before reading this thread. LOL. just wanted to do a search to see what results people were getting with the stuff.
after i saw some 07+s LGTs the other day, i realized how really bad mine were looking. also, the wife's car is pretty bad too, so i'm gonna give a whirl. Costs $7.99 at autozone. definitely worth the try at least. i didn't get any 2000+ sandpaper though. i'll try to post pics when i clean them (probably tomorrow or thursday when it stops raining).
good luck with yours.
Permatex sells a kit at auto part stores called Headlight restoration. It comes with a paste polish and graded sand papers (1000 up to 2000 I think) it worked great restoring my WRX lights and even used it to bring my Leggy back to new. Also used a mini ball polish to help the process and would make it easier to get inside your lens.
Ok guys... I ended up with the Permatex restoration kit, and it works very well. Its not COMPLETELY like new, but I'm pleased with the results....
Before:
http://photos-e.ak.fbcdn.net/hphotos-ak-snc1/hs003.snc1/2782_522858126682_72100768_30992700_8266583_n.jpg
After wet sanding with 1000,1500,2000, and 2500, before polishing (I was a little nervous at this point):
http://photos-g.ak.fbcdn.net/hphotos-ak-snc1/hs003.snc1/2782_523099323322_72100768_31000742_588239_n.jpg
After polishing with the stuff in the kit:
http://photos-h.ak.fbcdn.net/hphotos-ak-snc1/hs003.snc1/2782_523099338292_72100768_31000743_7757041_n.jpg
It still looked a little cloudy overall, so i went back and wet sanded with 2500 again, this time very very gently. Then I polished again, then I used some Maquires Cleaner Wax, and then some Maguires Quick Detailer spray:
http://photos-a.ak.fbcdn.net/hphotos-ak-snc1/hs003.snc1/2782_523099353262_72100768_31000744_3700538_n.jpg
As I said, I'm very pleased with the kit but dont expect a miracle without a lot of elbow grease! Its not like new, but unless you knew i messed with it, you wouldnt notice it a bit. Once I get the other headlight done and the car back together, I'll post 100% finished pics.
