Razor Posted April 17, 2009 Share Posted April 17, 2009 Any idea's where to start? Could this be bad tuning? Link to comment Share on other sites More sharing options...
rao Posted April 17, 2009 Share Posted April 17, 2009 Bad injector or coil. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Morbane Posted April 18, 2009 Share Posted April 18, 2009 I threw a cylinder 3 misfire (p0303 pfffe) the other day and my car's in the shop. I'll let you know if the mechanic knows what the problem is. I was running the stg 1 93 octane map Link to comment Share on other sites More sharing options...
Razor Posted May 11, 2009 Author Share Posted May 11, 2009 Morbane what was it in the end? Also, I seem to be able to clear the rough idle when it happends if i Rev the engine up to 3k+ in neutral ... any idea why it would do this? So far I have. 1. Inspected spark plug (looks fine) 2. Switched coilpacks from Cylinder 2 to cylinder 4 (problem still exists on cylinder 2) 3. Cylinder & Fuel injecter cleaner. Any more idea's guys? I'm out Link to comment Share on other sites More sharing options...
Spec B Posted May 11, 2009 Share Posted May 11, 2009 Swap the injector.. Link to comment Share on other sites More sharing options...
km580 Posted May 11, 2009 Share Posted May 11, 2009 Try disconnecting the plug for the injector on the bad cylinder, if the idle does not change, then it is a bad injector. Mine went on #1, I'm waiting for a new injector to come in on Wed. so I can replace it. Fat people are hard to kidnap!!! Link to comment Share on other sites More sharing options...
Morbane Posted May 14, 2009 Share Posted May 14, 2009 I've thrown the CEL for 3rd cylinder misfire twice even after my 30k service so I haven't got that sorted out yet. Link to comment Share on other sites More sharing options...
bdisco Posted May 18, 2009 Share Posted May 18, 2009 P0303 for me. Saturday night drop daughter #1 off at a birthday party, wife, daughter #2 and I start out for some pizza. On the way I get nasty vibration (flat tire?), slow down to pull over and car threatens to stall (blown turbo?). Pop the hood oil is not everywhere (whew) can't see anything loose. Car starts back up but engine is shaking like one of those beds you put quarters in at those cheap motels. Limp back home CEL and cruise flashing. Grab the AP (tell the wife "See this thing pays for itself.") Code P0303 Misfire cylinder #3 + two more ?????. Reset and add a bottle of Gumout octane boost. So far so good. Thursday the low fuel light came on for about 10 miles before I could stop at the gas station, maybe I picked up some sludge? Link to comment Share on other sites More sharing options...
Razor Posted May 18, 2009 Author Share Posted May 18, 2009 Well im still getting the rough idle and misfire and its getting worse. The dealership said they can't figure it out, and now ive been running my car for probably 4k miles with a intermittant rough idle. I've went from stage 1 back to stock and it is still acting up, no difference. Ive tried different oil and gas combinations. I'm going to try the injector next time it acts up, any more idea's guys? Link to comment Share on other sites More sharing options...
Razor Posted May 18, 2009 Author Share Posted May 18, 2009 Now there is a misfire on #4... great. Just baught the car and it's going to blow up. So frustrated Link to comment Share on other sites More sharing options...
Morbane Posted May 20, 2009 Share Posted May 20, 2009 Bad injector or coil. My injector was leaking fuel into the cylinder when it wasn't suppose to. This was causing very rough idle/occasional stall and 80psi in the cylinder. Link to comment Share on other sites More sharing options...
Razor Posted May 21, 2009 Author Share Posted May 21, 2009 its been two weeks now at the dealership. They are now saying they think the ECU is fried (cobb ate it!). There are some intermittant voltagaes not being supplied to two of the injectors. Any have any similiar problems like this? And how much is this going to run me? Link to comment Share on other sites More sharing options...
bdisco Posted May 26, 2009 Share Posted May 26, 2009 Nope, didn't just fix itself. Went to move the Subaru out of the garage to get out the tractor to mow the lawn and the rough idle/engine shake was back. Check engine light would come on and off but no flashing cruise. Does the computer not store a fault/error unless the cruise comes on? Access Port could find nothing. Re flash did nothing. If injector is bad, would it also foul the spark plug? If you switch STi injector do you have switch all four? How much cash we talking $$$??? Link to comment Share on other sites More sharing options...
bdisco Posted May 28, 2009 Share Posted May 28, 2009 Had local garage replace injector #3 yesterday. Car idles nice and smooth now. Accelerates good no hesitation. So far so good. Link to comment Share on other sites More sharing options...
Razor Posted May 31, 2009 Author Share Posted May 31, 2009 Well it turned out to be my ECM. $1300 bucks to replace, and they covered it for me. Wow! Im past all warrenty, and the car has been modified, pritty good eh? Link to comment Share on other sites More sharing options...
