Goyim Posted June 17, 2009 Share Posted June 17, 2009 The 50/50 mix should drop the afr half a point. U r running way too lean but its your car Link to comment Share on other sites More sharing options...
j255c Posted June 17, 2009 Share Posted June 17, 2009 You only want to be altering your POL table to reflect for the meth when it is spraying. You can adjust the boost point at which it starts spraying. Generally a good rule of thumb is half of your wg spring, or however much meth want to use. On stock turbo i wouldnt want it spraying until atleast 5psi, because that thing is always spooled. GL. POL table should be high 12's if you're running 100% meth or low 12's if you're running a 50 50 mix. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted June 17, 2009 Share Posted June 17, 2009 You're approaching an AFR of 13 in a few areas, which is a little higher than most like to be with meth. For comparison purposes, my AFR's don't go any higher than about 12.5. The 50/50 mix should drop the afr half a point. U r running way too lean but its your car Link to comment Share on other sites More sharing options...
lepich Posted June 17, 2009 Author Share Posted June 17, 2009 You're approaching an AFR of 13 in a few areas, which is a little higher than most like to be with meth. For comparison purposes, my AFR's don't go any higher than about 12.5. yes, this is an issue I can't fix so far. i mean on some conditions (ususllay - colder outside, morning) I see up to 13:1 AFR, but the same map gives me on hotter (day) temps 12-12:5 AFR. For now I've lowered OL AFR to get a lil bit richier mixture, to make it safer. Now I am getting 11.8-12.5 AFR on most logs/conditions. I have meth starting at 3.0-3.2 MAFv (its a MAF based controller), which is after 7 PSI for low RPM, and 4-5 psi on higher. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Spec B Posted June 17, 2009 Share Posted June 17, 2009 Load doesn't matter one bit if your MAF isn't scaled properly. MAF volts is a better gauge of power made or air being moved. Since load is off..wouldn't that mess up all the load based tables..like timing? Link to comment Share on other sites More sharing options...
j255c Posted June 17, 2009 Share Posted June 17, 2009 yes, this is an issue I can't fix so far. i mean on some conditions (ususllay - colder outside, morning) I see up to 13:1 AFR, but the same map gives me on hotter (day) temps 12-12:5 AFR. For now I've lowered OL AFR to get a lil bit richier mixture, to make it safer. Now I am getting 11.8-12.5 AFR on most logs/conditions. I have meth starting at 3.0-3.2 MAFv (its a MAF based controller), which is after 7 PSI for low RPM, and 4-5 psi on higher. I wouldnt go much over 12.0:1 on 93+Meth, especially without a proper failsafe. How much timing are you running btw? There is a section in the POL Table section called " Minimum Primary Open Loop Enrichment," as you can see the maximum amount a/f ratio it allows past 87.4% throttle duty is only 12.5, this may explain why you're not hitting your leaner A/F values. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
lepich Posted June 17, 2009 Author Share Posted June 17, 2009 ^^ I did modify that table, posted previously. And I have failsafe, it helped engine to suurvive couple of times. I do hit my leaner AFR targets, the only problem I have that AFR vary +-0.5. Probaly the pump, or something else in meth kit causing this. Overall, i am happy with it. Anyway, thanks! Edit: Sorry, it was another thread about that enrichment table.. ( http://legacygt.com/forums/showthread.php?t=105992&page=10 ) There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Infamous1 Posted June 17, 2009 Share Posted June 17, 2009 Since load is off..wouldn't that mess up all the load based tables..like timing? Yes, greatly. Im sure he has adjusted the timing tables following the MAF adjustments though. Link to comment Share on other sites More sharing options...
lepich Posted June 17, 2009 Author Share Posted June 17, 2009 ^^ Yes, timing was changed as well. I was datalogging a lot, making sure everything is Ok. BTW, I still under 3.2 g/s of load (max I have on my timing map), hitting 3.10 when its less then 80F outside.. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
j255c Posted June 24, 2009 Share Posted June 24, 2009 JFYI my pol table is all 12.63, a/f is 11.5-11.6 tapering to 11.3 @ 26psi from 4400-7200 at load levels from 2.2-4.2gs. The reason for the taper up top is that I am reaching maf levels that I could not hit on my pump map. I actually prefer the richer a/f up top as 26psi is a lot of boost and is providing additional cooling. I am probably sacrificing a little bit of power but im fine with that. This is on an m10nozzle spraying 90% Meth 10% water mix. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
lepich Posted June 24, 2009 Author Share Posted June 24, 2009 ^^ Wow. You got a huge turbo.. I am still on stock one, so its 13-12.5psi at redline.. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Infamous1 Posted June 25, 2009 Share Posted June 25, 2009 JFYI my pol table is all 12.63, a/f is 11.5-11.6 tapering to 11.3 @ 26psi from 4400-7200 at load levels from 2.2-4.2gs. The reason for the taper up top is that I am reaching maf levels that I could not hit on my pump map. I actually prefer the richer a/f up top as 26psi is a lot of boost and is providing additional cooling. I am probably sacrificing a little bit of power but im fine with that. This is on an m10nozzle spraying 90% Meth 10% water mix. Nice Forgot all about that td05-20g I bet. Link to comment Share on other sites More sharing options...
Ridgeracer Posted June 26, 2009 Share Posted June 26, 2009 I really liked some of the graphs/logs j255c posted of his old setup. Very nice street car. Now Shamar you know I have to say he should have "EWG that yo"... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
j255c Posted June 26, 2009 Share Posted June 26, 2009 I really liked some of the graphs/logs j255c posted of his old setup. Very nice street car. Now Shamar you know I have to say he should have "EWG that yo"... Ill post up some logs of this one once i've sorted everything out. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Ridgeracer Posted June 26, 2009 Share Posted June 26, 2009 You still getting tuned by Mike or are you self tuning? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
j255c Posted June 26, 2009 Share Posted June 26, 2009 little bit of both 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
