black318i Posted September 16, 2009 Share Posted September 16, 2009 It's only 60k for Hyundai. My accord was 90k and my wife's intrepid was like 105k or 110k. She ignored my warning and it snapped after only going a few hundred miles past the recommended interval. I think I'm going with Gates when I need to do mine. Link to comment Share on other sites More sharing options...
fishbone Posted September 16, 2009 Share Posted September 16, 2009 I always heard 100K is an average benchmark for timing belt replacement for all cars that use them. And which side of "err" do you think that is? Since I have not heard of a "rash" of failures, I submit it is on the safe side and the belt can go for more miles but it's not something you want to push your luck with. I am perfectly comfortable with 100K miles as a swap point. Hell, why not do it at 30K since that's TWICE as safe as 60k Link to comment Share on other sites More sharing options...
streetlethal1000 Posted January 21, 2010 Share Posted January 21, 2010 Just thought this might be a good place to drop a link to my "cam seal replacement" thread for any of you that have older legacy's. Link to comment Share on other sites More sharing options...
underpowerd Posted January 21, 2010 Share Posted January 21, 2010 Contact Fred Beans Suby. I heard more than once ppl mention that the STI and our belt carries the same part number. Confirmed....same part number.. yes, but there is also a 'heavy duty' STi-brand belt. reinforced, but i don't believe it is kevlar. when i was shopping belts, it was by far the most expensive of all the aftermarket replacement options. I settled on a PE kevlar II belt, which looks very much like a re-licensed gates; happy with it thus far after some 10k or so. Link to comment Share on other sites More sharing options...
SkiDaddy Posted January 22, 2010 Share Posted January 22, 2010 Pictures are gone on page one? Can the original poster please fix this? Thanks. Link to comment Share on other sites More sharing options...
GTTuner Posted January 23, 2010 Share Posted January 23, 2010 You have to remove the auto tensioner in the process. Most people will not have the proper tool to compress it, therefore just replace it and be done. Put it in a vise, SLOWLY compress it and insert the appropriate size pin or drill bit to hold it closed. Link to comment Share on other sites More sharing options...
Mickeytl Posted January 28, 2010 Share Posted January 28, 2010 I'm definitely planning on using Gates belts as well. My uncle who is a mechanic at subaru dealer recommends me to use Gates, if I don't go with oem belt. Link to comment Share on other sites More sharing options...
SkiDaddy Posted January 28, 2010 Share Posted January 28, 2010 Pics are back! Maybe it was my work computer? I made a tool to hold the driver's side cams together, I'll add a pic when I replace the belt. Any one know the torque on the harmonic balancer bolt for reinstallation? Use blue loctite? Link to comment Share on other sites More sharing options...
Ridgeracer Posted January 28, 2010 Share Posted January 28, 2010 Put it in a vise, SLOWLY compress it and insert the appropriate size pin or drill bit to hold it closed. Too late...Already threw out the old one....Next time I'll recycle to save the planet... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
underpowerd Posted January 28, 2010 Share Posted January 28, 2010 Any one know the torque on the harmonic balancer bolt for reinstallation? Use blue loctite? it's pretty well up there...something like 120 iirc. Link to comment Share on other sites More sharing options...
Guest Posted January 28, 2010 Share Posted January 28, 2010 Put it in a vise, SLOWLY compress it and insert the appropriate size pin or drill bit to hold it closed. Subaru is very adamant about not using a horizontal vise... Link to comment Share on other sites More sharing options...
mccorry Posted February 19, 2010 Share Posted February 19, 2010 Back into research mode... almost time to do my timing belt replacement.... Link to comment Share on other sites More sharing options...
derffred Posted March 13, 2010 Share Posted March 13, 2010 Yep, doin mine tomorrow =] Link to comment Share on other sites More sharing options...
DaveLang Posted April 17, 2010 Share Posted April 17, 2010 Interesting...thanks for putting together an informative post. I have a couple of questions; On a 2009 2.5na, what is a realistic life expectancy of the belt under normal driving conditions? Also, can anyone recommend a good Sub shop in the eastern Pa (berks) area? Thanks in advance! Link to comment Share on other sites More sharing options...
mattg Posted April 17, 2010 Share Posted April 17, 2010 Not sure why you would replace the belt and not the tensioner. Mine was leaking at 68k. BTW, I got my entire timing kit w/ Gates race belt, all pulleys & water pump off ebay for $315 shipped. Link to comment Share on other sites More sharing options...
croll326 Posted April 21, 2010 Share Posted April 21, 2010 If anyone wants to buy a new Gates timing belt I have one for sale.... I have the belt for sale from the Gates Timing Kit. I purchased the kit and their Racing Belt separately so I no longer need the belt that came in the kit....at least not until my 210k service lol. http://www.fredbeansparts.com/servlet/the-3690/Gates-Subaru-Legacy-GT/Detail Link to comment Share on other sites More sharing options...
mccorry Posted April 25, 2010 Share Posted April 25, 2010 Look up puzzled.... he might be interested in the belt... and he's in Pittsburgh, as well. Link to comment Share on other sites More sharing options...
just_phil Posted May 8, 2010 Share Posted May 8, 2010 So, if I take the belt off, the driver's side cams are going to move slightly? I've read the vacation pix a few times, but I'm still not sure if it's ok to let them move, or not? And if they move on their own, I need to move them back only in the proper direction? Thanks! Link to comment Share on other sites More sharing options...
mccorry Posted May 8, 2010 Share Posted May 8, 2010 I wouldn't let them move... I bought a cam lock tool for this. Link to comment Share on other sites More sharing options...
laramieskibum Posted May 8, 2010 Share Posted May 8, 2010 Just use a pair of vise grips to hold the top cam to the bottom cam. Worked fine for me last week. Link to comment Share on other sites More sharing options...
JBamin Posted May 10, 2010 Share Posted May 10, 2010 can i get a pic of someone doin the vice grip thing Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted August 1, 2010 Share Posted August 1, 2010 i think a video would explain that much better Link to comment Share on other sites More sharing options...
rob Posted September 8, 2010 Share Posted September 8, 2010 Just use a pair of vise grips to hold the top cam to the bottom cam. Worked fine for me last week. This means vice grips clamping the upper pulley to the lower pulley on both sides? I wonder if some quick clamps would work as well.... -Rob Link to comment Share on other sites More sharing options...
mccorry Posted September 8, 2010 Share Posted September 8, 2010 Vice grips work great, BTW. Link to comment Share on other sites More sharing options...
rob Posted September 9, 2010 Share Posted September 9, 2010 Vice grips work great, BTW. Again, just to clarify, this means vice grips clamping the upper pulley to the lower pulley on both sides? -Rob Link to comment Share on other sites More sharing options...
