Pricci09 Posted February 17, 2009 Share Posted February 17, 2009 Ok so I have a problem guys, My exhaust is extremly rusted out, to the point that I cant break loose the bolts connecting my y pipe to my mufflers, ive tried wd40..didn't help. Does anyone know of any good rust penetrators to help break loose those stubborn bolts? http://i30.photobucket.com/albums/c335/patrickdricci14/MariasChristmasGift0001.jpg ^my exhaust after 38k Link to comment Share on other sites More sharing options...
skiskank Posted February 17, 2009 Share Posted February 17, 2009 PB blaster Link to comment Share on other sites More sharing options...
PeterJMC Posted February 17, 2009 Share Posted February 17, 2009 PB blaster does the trick. You may want to use a breaker bar too Link to comment Share on other sites More sharing options...
rao Posted February 17, 2009 Share Posted February 17, 2009 Before you do any of that, make sure you have replacement nuts and bolts, because you are likely to break some Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Pricci09 Posted February 17, 2009 Author Share Posted February 17, 2009 im going to have to give pb blaster a shot, I assume just spray it on, let it soak..and go to work? good call, do you guys know what size the factory nuts and bolts are? Link to comment Share on other sites More sharing options...
tbssubaru Posted February 17, 2009 Share Posted February 17, 2009 those are 14mm, soak em with wd or pb, pray, use air tools if you got em ,,,, hook closed end of larger wrench in the open part of the 14mm wrench and use it for leverage Link to comment Share on other sites More sharing options...
