peteyjr Posted June 15, 2009 Share Posted June 15, 2009 Yes same kit. I bought it from AVO too. Comes with the metal adapter as well. Be aware they may have it backordered. You will have to do some slight mods to it for it to fit perfectly (nothing too difficult) I took pics of my install and mods needed so pm me if any questions. Link to comment Share on other sites More sharing options...
EJ252NA Posted June 16, 2009 Share Posted June 16, 2009 Yes same kit. I bought it from AVO too. Comes with the metal adapter as well. Be aware they may have it backordered. You will have to do some slight mods to it for it to fit perfectly (nothing too difficult) I took pics of my install and mods needed so pm me if any questions. Okay, thanks for the info! Will let you know. Link to comment Share on other sites More sharing options...
nka Posted June 17, 2009 Share Posted June 17, 2009 Well, I need this kit until I get money for the double din conversion Link to comment Share on other sites More sharing options...
nka Posted June 17, 2009 Share Posted June 17, 2009 To mount a 1 DIN HU replacing the cubby, I only need this : http://www.avojdm.com/product_info.php?manufacturers_id=11&products_id=102 ? hum.... or it's this kit : http://www.avojdm.com/product_info.php?cPath=26_54_60&products_id=115 What are the "minor" modifications ? Link to comment Share on other sites More sharing options...
peteyjr Posted June 17, 2009 Share Posted June 17, 2009 The minor mods are as follows: Slight trimming of the plastic piece inside the cubby in order for the single din radio to fit (easily done with a hack saw blade and 15 min of your time). Also the actual radio bezel That fits into the stock Air vent bezel has two pastic tabs that need to be removed. I also had to superglue it on as the press fit left a small gap . In the end it looks great and not hard to do. Link to comment Share on other sites More sharing options...
nka Posted June 17, 2009 Share Posted June 17, 2009 So, if I want to re-install the cubby someday cause I want to go double DIN, I'll be able or not ? Also, do I need this part http://www.avojdm.com/product_info.php?manufacturers_id=11&products_id=102 or this part http://www.avojdm.com/product_info.php?cPath=26_54_60&products_id=115 ? If I buy one of both, do not need anythings else (except wiring, I know) ? Great thanks ! Link to comment Share on other sites More sharing options...
peteyjr Posted June 18, 2009 Share Posted June 18, 2009 Not sure about the difference but it appears the first version does not have the radio bracket and the second one does (for $ 10 more) you should call or email AVO to clarify. You only need to buy the second version which comes with both bracket and radio bezel. Contact SVDX (another member for the forward and reverse wiring harnesses needed to do this. You can easliy change the cubby back to stock later I may do the DD eventually myself Link to comment Share on other sites More sharing options...
nka Posted June 19, 2009 Share Posted June 19, 2009 w00t thanks I miss a good HU and subwoofer Link to comment Share on other sites More sharing options...
UTwrestler22 Posted September 7, 2012 Share Posted September 7, 2012 OP, where'd you get the cubby kit and for how much? Link to comment Share on other sites More sharing options...
ichigoismyhomie Posted July 13, 2014 Share Posted July 13, 2014 OP, where'd you get the cubby kit and for how much? Ordered my kit last week and finally installed it last night. Total cost for the cubby kit ended up a little above 100 bucks shipped to california. Here's my install post http://legacygt.com/forums/showpost.php?p=4872972&postcount=31310 Link to comment Share on other sites More sharing options...
