Regal05LGT Posted February 3, 2009 Share Posted February 3, 2009 Essentially I'm retarded and forgot to put the bump stops on when I switched my suspension to koni/swift......should I put them on, or can I live without them?? Are they really that crucial?? Thanks, Link to comment Share on other sites More sharing options...
Regal05LGT Posted February 4, 2009 Author Share Posted February 4, 2009 Anybody got any input? Link to comment Share on other sites More sharing options...
ifbiker Posted February 4, 2009 Share Posted February 4, 2009 The bump stops are quite the little engineered piece of polymer. I would put them on especially since you have reduced your bump travel with the Swift springs and don't have any added "extra" protection from strut damage if you were to blow out. Keep in mind these things were designed to give more spring rate as they are engaged as well as strut protection. You may want to poll to see if anyone has shortened the bump stop while running Swifts. Link to comment Share on other sites More sharing options...
Regal05LGT Posted February 4, 2009 Author Share Posted February 4, 2009 I was def going to shorten them if I put them on, I think I am just going to put em in to be safe Link to comment Share on other sites More sharing options...
Underdog Posted February 4, 2009 Share Posted February 4, 2009 Swift specifically says in their instruction sheet that you don't need to cut the bump stops. However, the springs are designed for Bilsteins which supposedly have more travel. After riding with the bump stops installed for several months I wouldn't mind a bit more travel before hitting the stops. You definitely want some cushion in there in case you bottom out though. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Regal05LGT Posted February 4, 2009 Author Share Posted February 4, 2009 That's what i was thinking..... Just popped into my head the other day that I completely forgot to put them in lol.... I am going to wait til the weather doesn't suck anymore and get em on there for some reassurance Link to comment Share on other sites More sharing options...
