RaceComp Engineering Posted February 10, 2009 Share Posted February 10, 2009 "Essentially stock height" is fine....I would not recommend going any higher. - Andrew Link to comment Share on other sites More sharing options...
VTGT Posted February 10, 2009 Share Posted February 10, 2009 Mindspin what spring rates are you getting on your RCE's? I am pretty sure 350/350 spring rates was offered which could mean slightly better ride quality. Link to comment Share on other sites More sharing options...
Mindspin311 Posted February 10, 2009 Author Share Posted February 10, 2009 I decided to go with the 400/400 for now. If I get them installed and its just too harsh, Ill get the 350 springs and swap them. Here's hoping I dont need to do that. Link to comment Share on other sites More sharing options...
nm Posted February 10, 2009 Share Posted February 10, 2009 That's true, you can. You likely shouldn't. There should be clear instructions with the coil-overs as to what height range they can be used in. They can physically be adjusted outside of this range, but that will negate your warranty, and is outside of the range of travel that the actual damper is designed for. If you raise them up to high, you may not have enough droop travel. That being said, they range of adjustment does not lower your car too much at all. I drive mine through the whole winter in all conditions. I live in Winnipeg! That is thier max recommended height. I did RTFM Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 10, 2009 Share Posted February 10, 2009 That is thier max recommended height. I did RTFM Sorry buddy. When I got mine the ride height that was specified was actually a bit lower then stock. FWIW the max height changes depending on what top-hats you use, Spec-B ones or regular ones, but not by much. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
nm Posted February 10, 2009 Share Posted February 10, 2009 Sorry buddy. When I got mine the ride height that was specified was actually a bit lower then stock. FWIW the max height changes depending on what top-hats you use, Spec-B ones or regular ones, but not by much. Admittedly, I didn't measure the stock hieght, which is why I say essentially stock height. People assume I'm on stock suspension just looking at it though. I'm on spec B tophats. Link to comment Share on other sites More sharing options...
