05Boost Posted July 26, 2009 Author Share Posted July 26, 2009 not the greatest log since i was up high in rpm I just really wanted a look at what IDCs were and boost. http://www.mediafire.com/file/ttignjumdul/romraiderlog_20090725_202019.csv learning view [/url] http://www.mediafire.com/file/ihovhooozmg/LearningView_SS_7-25-2009 8 30 25 PM.jpg Link to comment Share on other sites More sharing options...
Infamous1 Posted July 26, 2009 Share Posted July 26, 2009 not the greatest log since i was up high in rpm I just really wanted a look at what IDCs were and boost. http://www.mediafire.com/file/ttignjumdul/romraiderlog_20090725_202019.csv learning view http://www.mediafire.com/file/ihovhooozmg/LearningView_SS_7-25-2009 8 30 25 PM.jpg Definately got some things we need to sort out up top and there is a bit of midrange boost spike as well. Link to comment Share on other sites More sharing options...
05Boost Posted July 26, 2009 Author Share Posted July 26, 2009 well itll all get fixed once all the parts are ordered. Going to just go with ewg seems like it will be a better option and i cant wait for the noise. Link to comment Share on other sites More sharing options...
05Boost Posted September 2, 2009 Author Share Posted September 2, 2009 http://www.mediafire.com/?sharekey=9394cd5740e488c461d4646c62b381cbe04e75f6e8ebb871 not a great log. IAM wasnt at 1 and i didnt rev it out. 4th gear pull. But peak went from 243g/sec to 263g/sec from switching out my mufflers (xo2 mid/y-stock mufflers before now stromung cattback) Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 2, 2009 Share Posted September 2, 2009 You really need to find out what's causing the IAM to drop before you start tuning boost. Also, your boost curve has a pretty large dip in it at 3400 rpm. Small dips are fine but this one is 2 psi. Your boost at 5000 rpm seems to be too high. It looks like the WGDC is winding down but it's not winding down fast enough or the WGDC initial is too high. Link to comment Share on other sites More sharing options...
Infamous1 Posted September 3, 2009 Share Posted September 3, 2009 Actually there seems to be some sort of mechanical issue, if you look at the WGDCs you can see you are approaching 0% although you are seeing 20+ psi. You are pretty much grossly over shooting the boost targets. I am almost positive the high boost is what dropped the IAM. No fuel cut CEL? Has there been any other changes since then? Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 Nope no changes other then exhaust. And no cels Link to comment Share on other sites More sharing options...
Infamous1 Posted September 3, 2009 Share Posted September 3, 2009 Something is keeping the WG shut, I am amazed that a vf series turbo can even achieve this kind of boost pressure. Regardless stay out of any hard driving until you get your new setup. There could possibly be a pinched line or something, that is some serious creep. Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 Since my new set up might not come for alittle long would a retune help me out some Link to comment Share on other sites More sharing options...
Infamous1 Posted September 3, 2009 Share Posted September 3, 2009 Since my new set up might not come for alittle long would a retune help me out some There are actually some mechanical issues that would need to be diagnosed first. Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 What kind of errors could I take a look at? Link to comment Share on other sites More sharing options...
testes1010 Posted September 3, 2009 Share Posted September 3, 2009 ^ pinched lines going to/from the bcs from/to the turbo, WG arm hitting heatshield, disconnect hose from wg & push open with hand to make sure opens fully. Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 Is there a picture guide of that? I'm not the most mechanicle person Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 another thing i just dont understand is if i didnt have these problems before I changed the exhaust, how come they are apparent now? Back to my first tuner, before i dynoed i was on stock exhaust beyond the downpipe, then I added the rest of the exhaust and thats when it got all messed up. Then I switched back to stock mufflers but with the rest of the 3inch turbo back and everything seemed normal. Its just my thinking, (im not as smart as you guys when it comes to all this) but could the stock mufflers with the 2.25inch piping have been that restrictive matting to the 2.5inch piping on the ypipe? Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 lower part of 3rd gear. http://www.mediafire.com/?jztjitztznf upper part of 3rd gear http://www.mediafire.com/?my2io3u2wu3 run through 2nd gear http://www.mediafire.com/?jjyzmerz01a Sorry there wasnt enough space to do anything really safely so this is all i could settle for. But IAM is at 1 edit: heres an edited version I just copied and pasted the numbers from the one log to the other as if it was a continous log http://www.mediafire.com/?yh0jyjuznmo and forgot to post Learning View http://www.mediafire.com/?ntxmzdikiza Link to comment Share on other sites More sharing options...
Infamous1 Posted September 3, 2009 Share Posted September 3, 2009 lower part of 3rd gear. http://www.mediafire.com/?jztjitztznf upper part of 3rd gear http://www.mediafire.com/?my2io3u2wu3 run through 2nd gear http://www.mediafire.com/?jjyzmerz01a Sorry there wasnt enough space to do anything really safely so this is all i could settle for. But IAM is at 1 edit: heres an edited version I just copied and pasted the numbers from the one log to the other as if it was a continous log http://www.mediafire.com/?yh0jyjuznmo and forgot to post Learning View http://www.mediafire.com/?ntxmzdikiza Could you just post them directly to the site? I cannot get access from work to mediafire. Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 I can do that for you when I get home. Just need to know how to do it Link to comment Share on other sites More sharing options...
Infamous1 Posted September 3, 2009 Share Posted September 3, 2009 Just like any other attachment, just select the file and upload it. Link to comment Share on other sites More sharing options...
05Boost Posted September 3, 2009 Author Share Posted September 3, 2009 hope that worksromraiderlog_20090903_121514.csvromraiderlog_20090903_121117.csvromraiderlog_20090903_121306.csv Link to comment Share on other sites More sharing options...
05Boost Posted September 4, 2009 Author Share Posted September 4, 2009 Anyone take a look at new logs? Link to comment Share on other sites More sharing options...
Infamous1 Posted September 4, 2009 Share Posted September 4, 2009 Your overboosting still but the creep isn't nearly as bad. This leads me to believe it may be something related to the BCS/pill setup. You are still running the two pill setup from the oem vf52 setup correct? Link to comment Share on other sites More sharing options...
05Boost Posted September 4, 2009 Author Share Posted September 4, 2009 What ever would normally happen when you just change out turbos is what happened. I didn't change anything during install Link to comment Share on other sites More sharing options...
jim1969 Posted September 10, 2009 Share Posted September 10, 2009 subscribed Link to comment Share on other sites More sharing options...
05Boost Posted October 4, 2009 Author Share Posted October 4, 2009 so i installed a perrin dp catted, uninstalled the invidia cattless. So how do these logs look. I think alittle better since the wastegate might have been blocked by the not fully shaved part on the invida.romraiderlog_20091004_113512.csv Link to comment Share on other sites More sharing options...
Infamous1 Posted October 4, 2009 Share Posted October 4, 2009 Still overboosting a bit, but it looks a lot better. Your timing may need a little smoothing here and there as well. Also it may be time for either a cleaning or replacing of your intake filter as well. Link to comment Share on other sites More sharing options...
