blue_obxt Posted February 19, 2005 Share Posted February 19, 2005 So Crutchfield has a wiring harness that they claim is for the '05 outback: http://www.crutchfield.com/S-pUJ0OprqCwB/cgi-bin/ProdView.asp?g=103000&I=120708901 It does look like it's the same connector that's on the back of our headunits (see photo in iPod install thread): http://www.legacygt.com/forums/showthread.php?t=2936 I know we can't replace the head units, but a wiring harness seems like a good place to start for adding an amp...that way you could avoid cutting into the existing harness. Now does anyone know where to find the female side of this connector? Link to comment Share on other sites More sharing options...
rao Posted February 19, 2005 Share Posted February 19, 2005 That is the generic Subaru connector and it will work, for the audio. You want a Scosche reverse harness S03-R if memory serves. I posted up the numbers a while back so a search would find them for sure, or just use your favorite search engine with 'subaru reverse harness" Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
blue_obxt Posted February 19, 2005 Author Share Posted February 19, 2005 Cool, found the reverse harness. It's the Scosche SU03RB. Thanks! Link to comment Share on other sites More sharing options...
mpaineau Posted February 22, 2005 Share Posted February 22, 2005 The 2004 Outback has a connector for a CD changer under the passenger seat. Is there a simple way to use this to direct connect an iPod? Link to comment Share on other sites More sharing options...
blue_obxt Posted February 22, 2005 Author Share Posted February 22, 2005 I'm afraid I don't know anything about the 2004 connector...the 2005's have an in-dash changer, so there's no connector. But the 2004's did have normal headunits, so you could always replace the factory head unit with something that has an aux-input... Link to comment Share on other sites More sharing options...
blue_obxt Posted February 24, 2005 Author Share Posted February 24, 2005 In case anyone cares, the 2005 harness uses one more pin on the wiring harness. The standard harness uses 13 of 14 possible pins, but the 2005 harness is now using the 14th pin as well. From the wiring diagrams in the service manual, it looks like this pin is carrying a second illumination signal. This makes sense, because the white and red lighting on the stereo is controlled separately (play with your headlights, dimmer switch, and trip computer light button and you'll get the idea). Anyways, I'm going to add the necessary wire to the harness that I'm making. Just need to buy the right crimp-on pins... Link to comment Share on other sites More sharing options...
rao Posted February 24, 2005 Share Posted February 24, 2005 That is the case on all WRX's 2002 on up. There are 2 wires for illumination a + and a - If you are using an aftermarket raadio you usually only need one or the other so you can just move the pin. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
blue_obxt Posted February 24, 2005 Author Share Posted February 24, 2005 This is in my 2005 outback, so I have to keep the headunit (adding an amp right now). I probably could just use one pin as you say, but I like the way the lighting works currently. I think I found the right pins on Digi-Key, so hopefully I will be able to add that extra pin. Link to comment Share on other sites More sharing options...
rao Posted February 24, 2005 Share Posted February 24, 2005 Or go to any stereo or electronics place and buy another harness for a more popular car that has similar pins (most of them are identical), like a Ford or GM and you will then have lots of extra pins for $10. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
blue_obxt Posted February 25, 2005 Author Share Posted February 25, 2005 Good point. I'll keep that in mind if my Digi-Key pins don't work out. Link to comment Share on other sites More sharing options...
SVXdc Posted May 1, 2005 Share Posted May 1, 2005 The radios in all Subaru models (except the SVX) since 1993 have been using this same 14-pin connector, and using two wires for illumination/dimming. Here's a pin-out table for the Legacy (with links to variations for the WRX and Forester). Here's a thread I put together on NASIOC with information about the stock head units. It includes a lot of information that applies to Legacies, including the extra connectors on the back for external CD changers: Stock head unit information -- pin-outs, aux inputs, and more As blue_obxt pointed out, the after-market harnesses (including the reverse one by Scosche) only have 13 wires. If you're keeping your stock head unit, you need all 14 wires for the illumination to work. See links from the pin-out table for an alternative solution. Link to comment Share on other sites More sharing options...
Eric L Posted May 1, 2005 Share Posted May 1, 2005 http://www.geocities.com/svxdc/Ordering.htm this guy will take care of you... Link to comment Share on other sites More sharing options...
Eric L Posted May 1, 2005 Share Posted May 1, 2005 http://www.geocities.com/svxdc/Ordering.htm this guy will take care of you... oops just noticed you posted Link to comment Share on other sites More sharing options...
al-gorithm Posted June 30, 2005 Share Posted June 30, 2005 Has anyone just tried to wire a gauge between illum+ and illum- to see if that would work with the dimmer switch? I was hoping that this would work. Otherwise I will have to try to build that elec. contraption mentioned above. Link to comment Share on other sites More sharing options...
SVXdc Posted June 30, 2005 Share Posted June 30, 2005 Has anyone just tried to wire a gauge between illum+ and illum- to see if that would work with the dimmer switch? ... If the gauge provides separate wires for both sides of the bulb (or LED), then yes, that will probably work. The problem is that a lot of gauges (so I'm told) connect one side of the bulb or LED to a common ground wire shared with the electronic "guts" of the gauge. In that case, you'll probably have to build that inverter circuit. Some people have opened up their gauge, disconnected the bulb/LED from the internal common ground, and connected a new wire going to the outside -- that gave them isolated connections to both sides of the bulb/LED, so they were able to use the Subaru's illumination wires as-is. Link to comment Share on other sites More sharing options...
