madcatz Posted January 14, 2009 Share Posted January 14, 2009 (Image provided and searched, but 02 or sensor comes up with crap) http://www.subarupartsforyou.com/images/products/NEWWRX.jpg I know what most the parts are, and G is the primary o2 sensor, or as Performance Subaru of New Orleans likes to call it the Fuel/Air Ratio Sensor, and NOT an o2, as well as saying the Sensor Post Turbo is the primary What is the sensor on the Up Pipe, and then the Second Sensor, post turbo is the Secondary o2 correct. A, C, D, K, L, Q, T : Gaskets B : Cross Pipe E : Cyl 3+4 Manifold F : Cyl 1+2 Manifold G : Primary o2 Sensor H : Cat. Up Pipe J : ?????? M : Cat. Down Pipe N : ?Secondary o2 Sensor? P : Cat. Mid Pipe R : Mid Pipe S : Exhaust Chamber W : Gee what could that be (DUH) (BTW: dont mind the fact no Y-Pipe or Second Chamber) -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
rao Posted January 14, 2009 Share Posted January 14, 2009 The sensor in the uppipe is the EGT sensor. The one labeled "N" is the post-cat O2 sensor. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
madcatz Posted January 14, 2009 Author Share Posted January 14, 2009 Thanks.....figured as much can you see the Primary o2 from looking just at the engine bay, or do you need to be below the car/in front of the engine....there is no way to see it without actually getting in there correct? -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
NSFW Posted January 15, 2009 Share Posted January 15, 2009 The main O2 sensor plugs into the exhaust manifold near the base of the up-pipe. I'm pretty sure you need to remove the undertray to get to it. Link to comment Share on other sites More sharing options...
SBT Posted January 16, 2009 Share Posted January 16, 2009 In Subaru's official parts list for the Legacy: G = Sensor, Front Oxygen, PN: 22641AA32A J = Sensor, Center Oxygen, PN: 22629AA012 N = Sensor, Rear Oxygen, PN: 226290AA69A (MT) 226290AA70A (AT) As was mentioned, J is typically known as the EGT Sensor while the other two are typically referred to as O2 Sensors (front and rear) - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted January 16, 2009 Share Posted January 16, 2009 Thanks.....figured as much can you see the Primary o2 from looking just at the engine bay, or do you need to be below the car/in front of the engine....there is no way to see it without actually getting in there correct? With the engine undercover on, the only sensors you can see is the UP one and the rear cat one. The front sensor can only be seen (unless you look through the oil filter access hole), with the front undercover off. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
