whitetiger Posted July 1, 2011 Share Posted July 1, 2011 those are stock size tires right? whats your alignment look like? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted July 1, 2011 Share Posted July 1, 2011 Awesome, thanks! It looks about a thousand times better for sure. http://farm6.static.flickr.com/5035/5889288377_5cbe2af3fe_b.jpg Hey sublime can you measure from the ground to the center of the fender well edge? Im curious what that measurement is at all 4 corners. I have my outback lowered on BC/BR coilovers and it looks to be about the same height as your LGT suspension. Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 1, 2011 Share Posted July 1, 2011 those are stock size tires right? whats your alignment look like? Yes sir, stock rims and tires. I have my alignment sheet in my car, I will scan it tomorrow and post. It is honestly really solid. The rear end was a bit of trouble but it eventually worked out. Hey sublime can you measure from the ground to the center of the fender well edge? Im curious what that measurement is at all 4 corners. I have my outback lowered on BC/BR coilovers and it looks to be about the same height as your LGT suspension. Yes sir, I will do it tomorrow. Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 1, 2011 Share Posted July 1, 2011 those are stock size tires right? whats your alignment look like? http://i.imgur.com/iLZiv.jpg Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 3, 2011 Share Posted July 3, 2011 Just measured the car, it is exactly 27" front and rear from ground to center of the fender well edge. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted July 3, 2011 Share Posted July 3, 2011 Cool thanks, I am pretty sure that is where mine is as well. Ill check it when the car gets back from Cobb Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 3, 2011 Share Posted July 3, 2011 Nice! I am trying to figure out what size rims to go with (I am a big planner so I want to get that figured out) and I don't want to lower it any more than it already is. What size rims and tires would I have to get so I have the same overall diameter that I have now with my stock rims and tires? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted July 3, 2011 Share Posted July 3, 2011 245 45 18 is what a lot of guys are running on the OB and it looks good. Look around on the forums there are a few with that size Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 3, 2011 Share Posted July 3, 2011 Nice, I would like to go a bit wider too, stock rims are 8.5" correct? Is 9" about as wide as I would want to go without getting that retarded "hellaflush" look? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted July 3, 2011 Share Posted July 3, 2011 stock outback XT rims are either 7 or 7.5 http://www.cars101.com should help you. You would want 18x8 48 offset I believe to run the 245 45 18 Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 3, 2011 Share Posted July 3, 2011 I am looking around a bit on here trying to find someone with an Outback on LGT suspension with aftermarket rims. Hard to phrase that for a search! Link to comment Share on other sites More sharing options...
Duffman Posted July 3, 2011 Share Posted July 3, 2011 I am running 235/45 17 on a set of BBS RX rims. They are 7.5" wide and that is the biggest they are rated for. I believe the stock rims you have (same as my stock) are only7" wide Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 3, 2011 Share Posted July 3, 2011 I am running 235/45 17 on a set of BBS RX rims. They are 7.5" wide and that is the biggest they are rated for. I believe the stock rims you have (same as my stock) are only7" wide 235/45/17 are rated for 7.5" or 7.5" is as wide as I can go in general? I don't want to have to do any modifications to fenders or anything like that. Link to comment Share on other sites More sharing options...
Duffman Posted July 6, 2011 Share Posted July 6, 2011 235/45/17 are rated for 7.5" or 7.5" is as wide as I can go in general? I don't want to have to do any modifications to fenders or anything like that. 235 is the widest for a 7.5" wheel. Link to comment Share on other sites More sharing options...
sethdreidel Posted June 4, 2015 Share Posted June 4, 2015 Got lost in the tread trying to find my answer, curious exactly which Legacy Gt I can swap from to do this the easiest? Thanks -Seth Link to comment Share on other sites More sharing options...
neddy1081 Posted December 24, 2015 Share Posted December 24, 2015 After the LGT spring/strut install any idea how wide of a tire can fit? I would like to get 9" wide tires under there. Link to comment Share on other sites More sharing options...
Rhitter Posted December 24, 2015 Share Posted December 24, 2015 It really depends on the wheel. A 9 inch wide wheel can fit given a low enough offset and the right size tire. It will require fender work though. My OBXT build Link to comment Share on other sites More sharing options...
neddy1081 Posted December 25, 2015 Share Posted December 25, 2015 It really depends on the wheel. A 9 inch wide wheel can fit given a low enough offset and the right size tire. It will require fender work though. What's your wheel set up? Link to comment Share on other sites More sharing options...
Rhitter Posted December 25, 2015 Share Posted December 25, 2015 I am currently OEM. My OBXT build Link to comment Share on other sites More sharing options...
neddy1081 Posted December 26, 2015 Share Posted December 26, 2015 I am currently OEM. Oh sorry it looked as though you had wheels in that avatar pic. Are you only on the lgt struts/springs? Link to comment Share on other sites More sharing options...
