SVXWRX Posted December 16, 2008 Share Posted December 16, 2008 was considering this, but i thought i remembered something about it not fitting to the factory midpipe section. anyone have it installed, opinions on sound with and without silencers? Link to comment Share on other sites More sharing options...
SVXWRX Posted December 17, 2008 Author Share Posted December 17, 2008 nobody has this exhaust? Link to comment Share on other sites More sharing options...
Brookmastr Posted December 17, 2008 Share Posted December 17, 2008 I have the megan setup with a dp and its quite quiet. Now once you are full gas 5000+rpm it roars. I like it not ot loud but can be if you have a heavy foot. The downpipe works well, and im judging with it all. Go for man, good price, good welds, nice look. No fitment problem what so ever went on in less then 30mins Link to comment Share on other sites More sharing options...
G.T.Subie Posted December 17, 2008 Share Posted December 17, 2008 you ne needs full catsbacks Denial is your best friend Link to comment Share on other sites More sharing options...
SVXWRX Posted December 18, 2008 Author Share Posted December 18, 2008 you ne needs full catsbacks i'm cheap and lazy. so the Megan axle back will bolt right up to the stock midpipe? yes or no, anyone? Link to comment Share on other sites More sharing options...
Brookmastr Posted December 18, 2008 Share Posted December 18, 2008 I dont see why not, i didnt have to get the dp, so i wouldnt worry at all. Should fit fine. Link to comment Share on other sites More sharing options...
G.T.Subie Posted December 19, 2008 Share Posted December 19, 2008 The megan will NOT connect to the stock Y-pipe. Denial is your best friend Link to comment Share on other sites More sharing options...
Brookmastr Posted December 19, 2008 Share Posted December 19, 2008 i apoligize I was talking about a cat-back I do not know whether it would fit i would say take the person aboves opinion. But about sound, like i said pretty quiet even with a catless dp. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 24, 2008 Share Posted December 24, 2008 he's talking about the stock midpipe on the stock DP. Its the lower section of the DP and YES the MR exhaust is designed to work with the stock full length down pipe. A catback exhaust is from the last cat all the way back which is from the full dp back. This includes the middle section with the resonator and y-pipe area and 2 mufflers. The megan middle to y-pipe section though does not work with any other muffler system other then megans. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
SVXWRX Posted December 24, 2008 Author Share Posted December 24, 2008 he's talking about the stock midpipe on the stock DP. Its the lower section of the DP and YES the MR exhaust is designed to work with the stock full length down pipe. A catback exhaust is from the last cat all the way back which is from the full dp back. This includes the middle section with the resonator and y-pipe area and 2 mufflers. The megan middle to y-pipe section though does not work with any other muffler system other then megans. thanks. i thought saw a while back that the Megan axleback did not fit to the factory Y-pipe (i have a Crucial shorty downpipe, and the rest of the exhaust back to the mufflers is stock). Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 24, 2008 Share Posted December 24, 2008 yeah the axleback doesn't fit the stock piping the MR mufflers only fit the MR pipe. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
SVXWRX Posted December 26, 2008 Author Share Posted December 26, 2008 yeah the axleback doesn't fit the stock piping the MR mufflers only fit the MR pipe. when are they going to correct their website? "Designed as a direct bolt-on to replace the stock piece, this axle-back system works in conjunction with the OEM Mid-Pipe and is easy to install within minutes." :unamused: Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 29, 2008 Share Posted December 29, 2008 your talking about the single tip? that one I don't know about I worked with the dual tip. This is the single http://meganracing.com/products/product_detail.asp?prodid=821&catid=133 OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 30, 2009 Share Posted April 30, 2009 bumping this old thread. Does the Megan single tip axleback bolt to the stock y pipe as advertised? Can anyone confirm this? Link to comment Share on other sites More sharing options...
eqt2010 Posted April 30, 2009 Share Posted April 30, 2009 ^ Nope. U need megan mid and Y pipes. Link to comment Share on other sites More sharing options...
brooklyngenius Posted April 30, 2009 Share Posted April 30, 2009 I think what it is is that they came out with the single tip after the dual so they are assuming you already had the y-pipe from the dual and are upgrading. Kinda wrong on their part useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
scoobydoobie Posted May 1, 2009 Share Posted May 1, 2009 Damn that sucks. I got excited to see a quiet and cheap set of axlebacks. http://www.cvrmotorsports.com/store/index.php?target=products&product_id=1813 This is misleading: This Axle Back Exhaust is a direct bolt-on to your existing exhaust system Link to comment Share on other sites More sharing options...
